Thread: My attampt at a Comp Wheely King
Old 06-04-2008, 03:06 AM   #1
Default My attempt at a Comp Wheely King
I started out doing the usual stuff like reversing the chassis and stretching the wheel base. Then i decided to buy an AX10 so i let my dad use the WK. But it just kept getting hung up and tipping over.
So i decided to do some work to it to make it compatible to the AX10.
I started with the transmissiom. It needed to be lower and i wanted the motor on the bottom.
Then it needed a new chassis, so i got out the hacksaw and files and started making one using the AX10 as a rough pattern.
I still have to make the battery mounts for the front axle but i thought i'd just show a few pics.
Thanks,
Neil
wknl is offline   Reply With Quote
Old 06-04-2008, 08:09 AM   #2
Shut up Dave
jetboat's Avatar
Im liking that motor plate...any chance you have a cad file of it?
jetboat is online now   Reply With Quote
Old 06-04-2008, 08:25 AM   #3
Sorry i don't. I don't have any software like that. But it really wasn't hard to make. I just cut a square piece of 2.5mm aluminium, cut of all the mounting points from the transmission housing. Laid it over the motor, where i wanted it to be, and marked it with a pencil.
Old 06-04-2008, 03:41 PM   #4
Can I help
Trace with a pencil on to a sheet of label sticker
Turn 90 degrees and draw motor mounting holes
Draw angle to fit skid plate
Remove sticker and place on your materiel of choice
I made this one last week
I hope this will explain it
SnoopMaxx is offline   Reply With Quote
Old 06-05-2008, 12:34 PM   #5
Location: ************************ Why crawl, when you can just jump up there?!
THIS is why i joined RCC people like Snoopmaxx will always willing to lend a helping hand. Great job on the info.
ADDICT is offline   Reply With Quote
