| | #1 |
| Quarry Creeper Join Date: Jan 2008 Location: Edmonton, AB
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: May 2006 Location: Pirkkala, Finland
| I'd leave a bit more material between the holes and chassis outlines. Some of the holes are quite close to each other too. |
| | #3 |
| ya i kinda thought that. i will mod it to what people suggest thanks |
| | #4 |
| Picky Fab'r/Acetal Junky ![]() Join Date: Jul 2006 Location: Arizona Desert/AJ
| Having the bottom curved like that is detrimental to what you want the skid plate to do...skid ...Unless of course you use a flat skid across the two bottom most holes in the plates and the side plate design at the bottom won't actually match the skid shape. |
| | #5 |
| AWESOME! TOTALLY AWESOME! ![]() Join Date: Oct 2007 Location: gervais
| it could be just for show with the arch? |
| | #6 |
| If you put the skid flat across the bottom but left the arch, then you could keep the look but still have a functional skid. Something like this, but you'd still need to round over the bottom points near the skid. |
| | #7 |
| i got ya. il make the change |
| | #8 |
| | #9 |
| Newbie Join Date: Oct 2005 Location: Fayetteville
| The new design looks much more capable. What kind of material are you thinking of using? |
| | #10 |
| what ever i can get my dirty little hands on!!! |
| | #11 |
| would this chassis use the stock wk tranny? or another? you should make some mounts if you tend to use the original tranny. |
| | #12 |
| Rock Crawler Join Date: Sep 2007 Location: Denmark
| Wery goo....... no Itīs an AWESOME design |
| | #13 |
| thanks. i dont know where the bolt holes go, i dont have dimensions for a stock wheely king trans. but i could find out. i had planed on running Harley's mount, but i need to find somebody that can cut it out with a CNC/Waterjet. |
| | #14 |
| Rock Stacker Join Date: Oct 2007 Location: australia,tasmaina
| can you send a copy of the chassis so i could build it. it looks hell capable |
| | #15 |
| If you go to my Wikispace(see Siggy) it on there as a PDF. got to RC Crawler on the left side nav bar. Thanks this is my first Frame and im gradually learning to use solid edge |
| Thread Tools | |
| Display Modes | |
