| | #1 |
| Newbie Join Date: Apr 2008 Location: Belgium
| Hi guys, I received a robinson 12T pinion for my wheely king crawler but it doesn't seem to fit any good... The pinion is so small that the motor bumps on the top of tha tranny before I have a good mesh. (I run a 96T spur btw) Anyone experienced this and has a solution ? Let me know if it is confusing, I'll try to post some pics. Thanks |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Sep 2007 Location: Denmark
| That is a common problem with that gearbox If you compare the AX 10 48P top gear ![]() witch the 17mm/D 15T Modul 1 on the WK ![]() You may have an idea of why it don´t fit The WK top gear is larger and so the small pinon´s will only fit on a much larger spur gear One of my friends use modul 0.5 100T spur vith an 11T pinon ![]() c",) |
| | #3 |
| Patterson Crawler ![]() Join Date: Jul 2007 Location: Pullman
| i just took my dremel to the top of the tran. You don't need much off the top. worked great for me. |
| | #4 |
| Rock Crawler Join Date: Feb 2008 Location: Nebraska
| That's the same thing that I did with mine . . . . |
| | #5 |
| Thanks for the explanation Snoop, and the feedback guys. I think I'll dremel the top and see how it works. Slowly byt surely ! |
| | #6 |
| Just did it and it's working great. The first run with my new Novak 55T and the 96/12 spur/pinion was amazing. What a change ! Thanks again for the tip. |
| | #7 |
| Pebble Pounder Join Date: Apr 2007 Location: at the bench of the up 'n coming '79 ford crew cab
| i had the same problem. same pinion and spur and motor. a lil dremeling changed a lot for the better! glad it worked for you! |
| | #8 |
| RCC Addict Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
| | #9 |
| Prick ![]() Join Date: Aug 2005 Location: Bargersville, Indiana
| I would have just ran a larger spur, but a dremel works too. |
| | #10 |
| | #11 |
| RCC Addict ![]() Join Date: Jun 2007 Location: Waterford
| If you change to 32p gears you can go bigger dia gears and get a good mesh!! |
| | #12 | |
| Quarry Creeper Join Date: Nov 2005 Location: Planet Earth
I got 100-110 I think and the max with stock chassis is about 104 teeth. Allows a tiny pinion from the same place. http://www.servocity.com/html/48_pit...ears__1_8.html | |
| | #13 |
| sweet i am going to have to got the biggist one that will fit in the chassis |
| | #14 |
| Newbie Join Date: Jun 2007 Location: Germany
| Hi! Could anyone please post a pic of a dremeled gearbox? Got the same problem, 95-14 doesn't mesh... Thanks a lot! Greetings from Germany! Rheinstahl |
| | #15 |
| Quarry Creeper Join Date: Jan 2008 Location: Edmonton, AB
| where do u find those/ who makes them? |
| | #16 |
| http://www.servocity.com/html/48_pit...ears__1_8.html that were I got it. I didn't even look at who makes it. I've never seen one before so I just ordered it and didn't even look. They had up to 150T I think. |
| | #17 |
| Newbie Join Date: Feb 2008 Location: Iceland
| Anybody got pictures after dremeling ? Yours Spot(T) |
| | #18 |
| all i did was take the motor plate off and use a flap wheely on the dremmel and sanded the top off it is really quite easy. i now have 90/14 gears waiting for the 96 spur to come in mail. i had to grind the motor plat alot too |
| | #19 |
| dang 150t....thats like -.5 mph |
| | #20 |
| Thread Tools | |
| Display Modes | |
