Thread: Clock Transmission drawing
Old 06-14-2008, 01:01 PM   #1
Patterson Crawler
A_Jeeper's Avatar
Default Clock Transmission drawing
Hey guys i have been working on a Clock transmission plate to post up as a pdf for people to use, if they like it. But I'm thinking i would like some thoughts on the drawing so far so i can work best for everyone. or if i have made a Monday morning mistake on it. thank for your guys help.
http://i29.photobucket.com/albums/c2.../RC/tran-1.jpg
A_Jeeper is offline   Reply With Quote
Old 06-14-2008, 01:34 PM   #2
Very Nice!! allz i need is the PDF, now. good job!
RockCrawlingKid is offline   Reply With Quote
Old 06-14-2008, 04:35 PM   #3
Center lines would be nice, it makes it easier to line up a punch so you can drill holes. 5 sets or so of center lines would be nice for the motor screw slot, that way we can drill 5 holes and file the rest. 2 sets for the motor bearing slot should be enough.
Hole sizes would be nice.
2 overall dimensions (X&Y) would help when looking for a piece of scrap.
HndsWthtShdws is offline   Reply With Quote
Old 06-14-2008, 05:48 PM   #4
Picky Fab'r/Acetal Junky
Offroader5's Avatar
Don't forget a way to bolt it down to the skid. Maybe design a flap of sorts at the bottom edge that can be bent 90 degrees after you cut the design out.
Offroader5 is offline   Reply With Quote
Old 06-14-2008, 09:05 PM   #5
Patterson Crawler
A_Jeeper's Avatar
I didn't want to put a mount on it because I don't know how each person is going to want to mount the bottom part of there transmission. Which would change were the mount on the plate would be. I was going for something that everyone can use no matter how they mount it. But if you or anyone else would like anything added special to it PM me and i can draw it any way you want it.
Old 06-14-2008, 09:09 PM   #6
Patterson Crawler
A_Jeeper's Avatar
email sent
Old 06-15-2008, 01:05 AM   #7
Looks good, can I get a PDF sent to me?
DirtRacinFool is offline   Reply With Quote
Old 06-15-2008, 09:09 AM   #8
x2 can I have one PLZ
c",)
SnoopMaxx is offline   Reply With Quote
Old 06-15-2008, 10:00 PM   #9
Patterson Crawler
A_Jeeper's Avatar
I'll send them out tomorrow morning when i get on my computer. If any one else wants one let me know and i will send the PDF off all at once.
Old 06-15-2008, 10:19 PM   #10
After you print it make sure everything lines up. Sometime printers scale jobs slightly even though you selected 1:1. When I make templates like this I like to draw rulers in the X & Y directions so its easy to check.
Old 06-15-2008, 10:19 PM   #11
once i get a copy ill put it on my wikispace if it's ok with u(i say thanks to whoever i get it from).
Old 06-15-2008, 11:33 PM   #12
I also would like a pdf of this motor plate please. thanks.
iceman320 is offline   Reply With Quote
Old 06-16-2008, 05:22 AM   #13
I'd like a PDF also, please
krush groove is offline   Reply With Quote
Old 06-16-2008, 09:47 AM   #14
PM'ed ya for a PDF
friscokidd is offline   Reply With Quote
Old 06-16-2008, 12:43 PM   #15
Patterson Crawler
A_Jeeper's Avatar
Thats cool with me. I would do it, but i don't know how.
Old 06-16-2008, 02:33 PM   #16
PM'd for a PDF as well...
Garcol is offline   Reply With Quote
Old 06-16-2008, 04:39 PM   #17
it on me wikispace see siggy!
Old 06-16-2008, 07:20 PM   #18
Patterson Crawler
A_Jeeper's Avatar
since i sent it BCC i got one. and when i opened it to look at it it was like two times the size. i fixed it and resent the email. sorry about the mess up every one.
Old 06-16-2008, 08:42 PM   #19
it all good on my wikispace now too!!!
Old 06-16-2008, 10:03 PM   #20
Nice work guys I'll be using this soon. The resized version is dead nuts
DeaDShorT is offline   Reply With Quote
