| | #1 |
| Quarry Creeper Join Date: Feb 2008 Location: Irvine KY
| will an axial tranny fit on the wk on another chassis with the same drive shafts?? |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Jan 2008 Location: Edmonton, AB
| no, wk has 6mm drive pins and axials have 5mm drive pins. if u have the hardend axle gear set for the king axles you could go ahead cause they are 5mm like the axial. you would need new bearings in the axle though. im pretty sure that this is correct. i might be rong on some stuff |
| | #3 |
| Rock Crawler Join Date: Jan 2007 Location: Midway
| If I remember corectly there are output shaft converter parts available for converting from 5mm to 6mm and vise versa to allow for this problem. Found them see this link. http://rc4wdstore.com/index.php?cPath=3 |
| | #4 | |
| RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
i thought about those. but i ended up drilling a small hole just big enough for maxx shafts in the trans out put | |
| Thread Tools | |
| Display Modes | |
