08-05-2008, 09:50 PM | #1 |
Newbie Join Date: Jul 2008 Location: RGV, TX
| Just started my build
Well I just got my WK about a month ago and started to get to work on it to make it into a crawler. I finished up today on a few mods. I kept it as a 3 link for now but I have the stuff to make it into a 4 link. I just finished it up a just a bit ago and had to take it out in the dark to see how it ran. After a couple of min I was hooked and now I just need to keep adding to it. Here are a few pics of what I have done. Custome Lower Links STRC Lockers Traxxas link rear lockouts Traxxas Drive Shafts Here is somethings that is to come to match my 1:1 -Eddie |
08-05-2008, 09:57 PM | #2 |
Newbie Join Date: Jul 2008 Location: South Decatur
Started my first build tonight as well. Axial scorpion, made it all the way through "bag B".
08-05-2008, 10:08 PM | #3 |
Quarry Creeper Join Date: Jan 2008 Location: Edmonton, AB
nice trucks. lovin the hemi |
08-08-2008, 03:32 PM | #4 |
Rock Stacker Join Date: Jan 2008 Location: Q-Town
Truck is looking really good so far, what rim/tire combo are you going to use. Your 1:1 is a sweet ride...
08-09-2008, 04:50 PM | #5 |
Worked on the new body today. This was my frist attempt and I still need to work on the body a little bit in order for the truck to flex. I'm also working on my servo mount too. Here it is next to my 1:1. -Eddie |
08-09-2008, 05:13 PM | #6 |
Newbie Join Date: Oct 2007 Location: Trevose
Should have went wiht a gun metal color, but it looks good man! -Jesse |
08-09-2008, 05:33 PM | #7 | |
-Eddie | |
08-09-2008, 05:34 PM | #8 |
sorry, even better a cummins |
08-09-2008, 05:36 PM | #9 |
08-09-2008, 07:04 PM | #10 |
yup. i would definatly make it 4 link now |
08-10-2008, 04:33 PM | #11 |
I was able to 4 link the front and move my servo with some left over parts I had. I just need to take it back apart and fix the upper links a bit as well as fix my servo. Next up I will go get some supplies to make the existing links look better as well as 4 link the rear. -Eddie |
09-18-2008, 08:43 PM | #12 |
Made some changes to the truck. This was my first attempt at making a chassis and it came out ok but I am going to make another one. The 4 link in the front needs to be worked on in order to get a better drive shaft angle. So I will keep on working on it till it performs the way I want it to. Custom Chassis STRC Lockers Traxxas turnbuckle rear lockouts Traxxas driveshafts Axial wheels/tires Custome front and rear 4 link T-Maxx springs in the front 60wt Oil Relocated servo Next thing up will be to start replacing all the stock stuff. -Eddie |
09-18-2008, 10:05 PM | #13 |
Quarry Creeper Join Date: Apr 2008 Location: Clay, Alabama
How did you mount your upper link mount to the axle? I'm doing something very similar, and I have a problem with the mount twisting, since I can only get one screw in it. Good looking rig... |
