| | #1 |
| Rock Stacker Join Date: Jan 2008 Location: Laurens SC
| There use to be a guy selling alum. 4 link upper mounts on ebay now i cant find them. Do you guys know any one selling Alum. mount for the axle to allow me to run a true 4 link suspension vs the 3 link |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Apr 2008 Location: dallas
| i used these mounts.. they work great for triangulated upper link (4) mounts http://www3.towerhobbies.com/cgi-bin...&I=LXGKG9&P=ML |
| | #3 |
| if you look at the picture of these mounts. I used the ones on the top.. |
| | #4 |
| Then I used these for the lowers http://www.ckrccrawlers.com/shop/ind...roducts_id=375 |
| | #5 |
| I have something similar to that now. issue is the torque of the motor is bending them. I was hoping for something stronger. i will try to get a pic of what a buddy has tonight. |
| | #6 |
| . ![]() Join Date: Nov 2005 Location: Rock chucking territory
| | #7 | |
| Quote: | |
| | #8 | |
| Rock Crawler Join Date: Apr 2007 Location: St. John's
| | #9 |
| | #10 |
| | #11 |
| Good work, I may copy you!! |
| | #12 |
| Rock Crawler Join Date: Sep 2007 Location: Denmark
| | #13 |
| | #14 |
| RCC Addict Join Date: Nov 2007 Location: Scalers are more fun
| I used Aluminum angle to mount up some TLT servo plates. It worked very well, and gave me a lot of options for upper link position. I didn't care for the VF upper link mounts, It didn't allow me to get good geometry with the axles clocked up. Pics here Bowser the WK! |
| | #15 |
| NIDRCRC.com ![]() Join Date: Jul 2005 Location: Rathdrum, ID USA
| Or you could keep it simple... I haven't broke the little plastic link mount yet going this way. |
| | #16 | |
That's what I had to make the aluminum ones you see in top half of the picture I posted earlier. I simply made the mount to fit over the back of the pumpkin (using the template from the servo mount for the correct shape and bolt hole location). Then I bolted the Tamiya stay mounts to the aluminum mount plate. My bolts go all the way through the diff cover and are nutted on the back. I did this after I snapped off the heads of several of the stock screws - not from over-torquing but from serious falls that caused the link mount to pull the heads off the screws. Not a hitch since I made the new mounts | |
| Thread Tools | |
| Display Modes | |
