Thread: WK Crawler Conversion FINALLY!
Old 09-24-2008, 03:43 AM   #1
Default WK Crawler Conversion FINALLY!
well after three months i finally got it but unfortunatly i allready modded the crap outta my WK so i stole my brother inlaws and after about 3 hours i have to say im impresed by the articulation and setup, all it needs is a split battery pack for the axles and an axle servo mount but seems how its not mine i think ill leave it as is and use it as a mudder if he doesnt want it back right away (if at all), Wiull post picks when i can get some better lighting in the morning.
Tonelock is offline   Reply With Quote
Old 09-24-2008, 05:18 AM   #2
I also just got done installing the conv. kit along with their gear reduction box.
The kit is nice and not to bad to install, the gear reduction box is easy to install also but it is very noisy when running and it realy slows down the WK as it should it also has enough gear reduction it acts as a drag brake.
I have Pro-Line M2 Flat Irons tires w/ memory foam and Pro-Line 8 Shooter beadlocks coming it today. I also am also making a front axle servo mount and new steering linkage.
I also upgrade the steering servo now to a TowerPro M995
EARRNHARDT3 is offline   Reply With Quote
