Thread: ground clearance on a wheelyking
Old 09-26-2008, 04:42 PM   #1
Default ground clearance on a wheelyking
got my chassis extended and both diffs locked crawls like a dream but when i go over taller rocks i bottom out way to much i have got the original mudking tires would a real rock tire help it being taller?
killerflexhpi is offline   Reply With Quote
Old 09-26-2008, 05:40 PM   #2
If they are taller yes, but also a skid plate would help if you are wanting to stick with the stock chassis.
Bestdallasfan6 is offline   Reply With Quote
Old 09-26-2008, 09:42 PM   #3
~Doin' it Dawg style!~
TrailDawg362's Avatar
If you're good with modding/fabbing, you could do the "tummy tuck" mod to the stock chassis. I made aluminum side plates to fit inside the plastic chassis where the guts mount up for strength. Do a search or check the thread for more info.
T.D.
TrailDawg362 is offline   Reply With Quote
Old 09-27-2008, 11:56 AM   #4
Patterson Crawler
A_Jeeper's Avatar
that mud king are just about the tallest tire out there for the 2.2 that i have seen. I was going to do the tummy tuck to mine then i just made a new chassis instead. but if you want to do the tummy tuck i have a drawing for a skid that wraps around the bottom of the chassis. in fact i have one made up because some one ordered one from me then never payed for it.
A_Jeeper is offline   Reply With Quote
Old 09-27-2008, 01:47 PM   #5
About the only tire taller than Mud Thrashers is maybe Imex Red Rocks. They hook up alot harder than the stockers, which might shorten the life of your gears.
T.D.
Old 09-28-2008, 12:44 PM   #6
i have the IMEX A/T's, theyre as tall and wide as the stockers. they get better grip too.
gearguy70 is offline   Reply With Quote
Old 09-28-2008, 08:28 PM   #7
I'm planning to dog out the stockers on mine next time I take mine in the mud
BJoe is offline   Reply With Quote
Old 09-29-2008, 05:34 PM   #8
thanks for all the info guys im thinking of getting the flat irons but dunno yet hey nathan lime can u maybe send me a link or someway or even post a pic of that skid plate so i can get an idea?
