12-17-2008, 12:41 PM | #21 |
Quarry Creeper Join Date: Jul 2006 Location: In a tree top with my chainsaw!!
So, other than the grinding on the pinion, did you need to do anything to the ring gear and diff housing to make them fit? I have some e savage diffs lying around and also some WK axle housings that need gears. Thanks for the info. Sorry about your loss. ED |
12-17-2008, 03:05 PM | #22 | |
Pebble Pounder Join Date: Jul 2007 Location: Shorewood
ps will and to end of right up | |
12-18-2008, 06:34 AM | #23 |
Quarry Creeper Join Date: Nov 2005 Location: Planet Earth
Are they both the same teeth as stock?
12-18-2008, 01:02 PM | #24 |
12-18-2008, 06:05 PM | #25 |
Rock Crawler Join Date: Dec 2007 Location: USA
12-18-2008, 07:44 PM | #26 |
| same teeth number 38 ring 13 pion
12-22-2008, 09:24 AM | #27 |
Yes, thanks.
12-23-2008, 06:45 AM | #28 |
12-23-2008, 08:45 AM | #29 |
Rock Crawler Join Date: Sep 2007 Location: Denmark
| Great little write up I haven´t had time to rebuild my diff´s yet :-( |
12-30-2008, 06:58 AM | #30 |
12-31-2008, 03:35 PM | #31 |
01-02-2009, 11:10 AM | #32 |
03-11-2009, 12:47 AM | #33 |
RCC Addict Join Date: Jun 2008 Location: Mudville
anyone aware of a complete diff with a smaller ratio that will drop right in(wiht shims ofcourse) that is a lower ratio? i would like a decent ratio for good wheel speed.
03-21-2009, 08:45 AM | #34 |
Quarry Creeper Join Date: Dec 2008 Location: Post Falls, ID
this must be what i need to do! I am new to the wheely king scene, so now i know why mine clicks. does it usually happen i the rear first? or is it only clicking in the rear cuz it was 2wd first and those gears were more used? has anybody found a drop in solution that works without grinding? |
04-15-2009, 09:09 PM | #35 |
Quarry Creeper Join Date: Nov 2007 Location: Cincinnati
06-26-2009, 09:20 PM | #36 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
good to know about the gears i am building my wk crawler and the diff gears are cracked in several places in both axles so i have to rebuild them
