Thread: Ebay Wheely King Build
Old 09-28-2008, 09:56 PM   #1
Default Ebay Wheely King Build
We have been working on our ebay WK for a month now and have finished the crawler conversion.
I think I need better ideas on how to get the axles a little flatter!
Any suggestions?
We like the ride height, but the truck gets high centered alot!
Thanks for any help!
r2d2dad is offline   Reply With Quote
Old 09-28-2008, 11:55 PM   #2
I don't know what you mean about getting the axles "flatter." As for the ride height, you're already running it higher than I would. Getting high centered is part of the deal, if you're getting stuck all the time, you should work on finding better lines. I never ran my WK with more than 2 1/4" of ground clearance with wheels on it.
chrisjlittle is offline   Reply With Quote
Old 09-29-2008, 01:34 AM   #3
if you shorten the top link arms a bit you will get a pitch angle on your tail shaft
the rear shaft on mine sat the same as yours easy fix
BIG PETE is offline   Reply With Quote
