Thread: Wheely King Project Study - need help
Old 10-01-2008, 12:44 PM   #1
Default Wheely King Project Study - need help
Hi guys,
I am working on this project at college and we decided to work on the Wheely King cuz its wayyyyy more fun then working on a toaster or an umbrella (LOLOL)
Anyways, we need to conduct a user study for our product to identify possible ways to redesign our Wheely King 4x4 and could really use your help. If you guys could spend 5 minutes of your time to answer the following questions, that would be truly appreciated
  • Have you ever used the Wheely King 4x4 before?
  • What age bracket do you fall under?
    • 0-18
    • 18-35
    • 35+
  • Why did you buy the Wheely King? (Tick all that apply)
    • Racing
    • Rock Crawling
    • Fun
    • Annoying family members
    • Passing time
    • To perform wheelies
    • Other (please specify)
  • How does the Wheely King compare with other RC Rock Crawlers? (Rate the following based on the scale below)
1 (The best)
2 (Good)
3 (Average)
4 (Bad)
5 (The worst)
Cost
Racing Performance
Rock Crawling Performance
Speed
Maintenance
Assembly & Disassembly
Ease of Upgrade
  • What are the specifications of your original Wheely King?
  • What modifications have you made to your car & how has that improved the performance?
  • What disadvantages do you see with the original Wheely King?
  • When you first used the Wheely King, what problems did you face? How did you resolve them?
  • Does the Wheely King perform the function that you bought it to perform? (See Question 2)
  • What design modifications would you suggest to improve the overall experience of your Wheely King?
IntelAgression is offline   Reply With Quote
Old 10-01-2008, 02:57 PM   #2
Originally Posted by IntelAgression View Post
Hi guys,
  • Have you ever used the Wheely King 4x4 before? Yes
    • 0-18
    • 18-35 *
    • 35+
    • Racing
    • Rock Crawling *
    • Fun *
    • Passing time
1 (The best)
2 (Good) *
3 (Average)
4 (Bad)
5 (The worst)
Cost
altogether 600
Racing Performance none
outstanding
Speed
SLOW
Maintenance
lots
Assembly & Disassembly on a scale of 1 to 10 about a 8
Ease of Upgrade fully upgraded
  • What are the specifications of your original Wheely King? stock
  • What modifications have you made to your car & how has that improved the performance? New chassis upper and lower links servo mounts clocked tranny 4 wheel stering locked tranny and axels
  • What disadvantages do you see with the original Wheely King? its stock
  • When you first used the Wheely King, what problems did you face? How did you resolve them? Modified rite out of the box never played with it stock
  • Does the Wheely King perform the function that you bought it to perform? (See Question 2) sure
  • What design modifications would you suggest to improve the overall experience of your Wheely King? new chassis
larry
RnRJeep is offline   Reply With Quote
Old 10-01-2008, 04:43 PM   #3
35+
Fun
(Out of the box?)
4 - Bad
Cost
$209 (Stock)
Racing Performance
N/A
Low when stock, great now
Speed
Depends on what motor I have in it
Maintenance
Good
Good
Ease of Upgrade
Great
Stock
New chassis, links, transmission, servo, ESC, driveshafts, motor, beadlock wheels, crawler tires
The original ESC (Jolt) was junk. It smoked the first day.
The ESC burned up
I bought a Novak XRS
Does the Wheely King perform the function that you bought it to perform? (See Question 2) It has been a lot of fun.
Offer one that comes with HPIs new rock crawler conversion kit in the box.
kwkride is offline   Reply With Quote
Old 10-01-2008, 05:25 PM   #4
    • 0-18
    • 18-35
    • 35+ *
    • Racing
    • Rock Crawling *
    • Fun *
    • Passing time
1 (The best)
2 (Good)
3 (Average)
4 (Bad)
5 (The worst)
Cost
2
Racing Performance 5
Rock Crawling Performance MODIFIED 2 , STOCK 4
Speed 2
Maintenance 2
Assembly & Disassembly 2
Ease of Upgrade 1
  • HPI Crawler kit installed , HPI gear reduction box installed, High torque steering servo, Pro-Line Flat Iron tires, Pro-Line 8 Shoter bead locks and 6 oz. of lead in each front wheel. chassie flip,
  • It crawles alot better now.
  • To much plastic parts
  • No real problems
  • Yes
  • More metal parts , better trany , better ESC.
EARRNHARDT3 is offline   Reply With Quote
Old 10-01-2008, 07:02 PM   #5
  • Have you ever used the Wheely King 4x4 before? yes
    • 0-18
    • 18-35 *
    • 35+
    • Racing
    • Rock Crawling
    • Fun *
    • Passing time
    • To perform wheelies *
1 (The best)
2 (Good)
3 (Average)
4 (Bad) * stock
5 (The worst)
Cost
$200.00
Racing Performance
Speed Fine for stock
Maintenance Pretty easy
Assembly & Disassembly Pretty easy, servo and linkage are kinda lame to get at
Ease of Upgrade Great
  • What modifications have you made to your car & how has that improved the performance? Nothing yet.
  • What disadvantages do you see with the original Wheely King? It's a fun little basher truck, great to let other people use because it's so tough.
  • When you first used the Wheely King, what problems did you face? How did you resolve them? Broken stock servosaver. I put in a better one.
  • Does the Wheely King perform the function that you bought it to perform? (See Question 2) Yes, I bought it to bash
  • What design modifications would you suggest to improve the overall experience of your Wheely King? Servo mounted on the axle.
There ya go
sdcrawls is offline   Reply With Quote
Old 10-01-2008, 07:45 PM   #6
Rob
0-18
To build a rock crawler
1 (The best)
2 (Good)
3 (Average)
4 (Bad)
5 (The worst)
Cost
2
Racing Performance
5
1
Speed
5
Maintenance
1
3
Ease of Upgrade
2
Rob is offline   Reply With Quote
Old 10-02-2008, 12:14 AM   #7
    • 18-35
    • Rock Crawling
    • Fun
    • Other (please specify) Parts truck
1 (The best)
2 (Good)
3 (Average)
4 (Bad)
5 (The worst)
Cost
2
Racing Performance
4
2
Speed
3
Maintenance
1
3
Ease of Upgrade
2
  • What modifications have you made to your car & how has that improved the performance? Lockers and longer links. Crawls alot better.
  • What disadvantages do you see with the original Wheely King? Top heavy and alot of plastic
  • When you first used the Wheely King, what problems did you face? How did you resolve them? It would barely do a wheely with stock battery so I put a better one in.
  • What design modifications would you suggest to improve the overall experience of your Wheely King? Turn the chassis around so the battery is in front and lock the axles
mutiny22 is offline   Reply With Quote
Old 10-02-2008, 10:06 AM   #8
I would like to thank everyone who has responded so far...
If my team successfully redesigns the HPI Wheely to improve on the stock version, there is a possibility that our final prototype and recommendations will be forwarded to HPI.
Therefore, we need as many respondents as possible...So, please keep responding people...
Old 10-02-2008, 11:05 AM   #9
  • Have you ever used the Wheely King 4x4 before? - Yes
  • What age bracket do you fall under? - 35+
    • Fun
    • Passing time
    • Other - I have a crawler... wanted something to bash on
1 (The best)
2 (Good)
3 (Average)
4 (Bad)
5 (The worst)
Cost - 2
Racing Performance - 4
Rock Crawling Performance - 4
Speed - 3
Maintenance - 2
Assembly & Disassembly - 3
Ease of Upgrade - 2
Other (please specify) - Fun Factor = 1
  • What are the specifications of your original Wheely King? - Stock
  • What modifications have you made to your car & how has that improved the performance? - None yet
  • What disadvantages do you see with the original Wheely King? - None
  • When you first used the Wheely King, what problems did you face? How did you resolve them? - No Problems
  • Does the Wheely King perform the function that you bought it to perform? - Yes
  • What design modifications would you suggest to improve the overall experience of your Wheely King? - If you want a Rock Crawler - Buy a Rock Crawler, if you just want a fun truck to bash around buy a Wheely King and just run it and have fun!
gadget is offline   Reply With Quote
Old 10-02-2008, 12:33 PM   #10
Mriswith's Avatar
  • Have you ever used the Wheely King 4x4 before? - Twice
    • 0-18
    • 18-35
    • 35+
    • Racing
    • Rock Crawling
    • Fun
    • Passing time
1 (The best)
2 (Good)
3 (Average)
4 (Bad)
5 (The worst)
Cost
3
Racing Performance
4
4
Speed
4
Maintenance
2
2
Ease of Upgrade
4
  • What are the specifications of your original Wheely King? - 4x4 RTR version
  • What modifications have you made to your car & how has that improved the performance? - Chassis, transmission, steering servo relocated, axle link mounts/truss, rear steer lockout, replaced all links, upgraded axle ring/pinion gears, locked diffs, equal length 4-link bars (Only the axles are left from the original kit and the internals have been upgraded)
  • What disadvantages do you see with the original Wheely King? - poor steering. Needs extensive modification to be a competition caliber crawler but it wasn't initially designed for Rock Crawling. Minor mods make it a capable basher/trail rig
  • When you first used the Wheely King, what problems did you face? How did you resolve them? - Marginal Electronics = Replaced all RTR kit electronics, Center of Gravity/Gear ratio = Swapped stock trans for Axial AX10 trans, Plastic links = metal links
  • Does the Wheely King perform the function that you bought it to perform? (See Question 2) - Stock = No, After mods = yes
  • What design modifications would you suggest to improve the overall experience of your Wheely King? - Compact, low mounted motor design
Here's my submission
Mriswith is offline   Reply With Quote
Old 10-02-2008, 02:21 PM   #11
  • Have you ever used the Wheely King 4x4 before? No
    • 0-18
    • 18-35
    • 35+
    • Racing
    • Rock Crawling
    • Fun
    • Annoying family members :smile:
    • Passing time
    • Other (please specify) Formula Off-Road
1 (The best) 2 (Good) 3 (Average) 4 (Bad) 5 (The worst) Cost 3
Racing Performance 4
Rock Crawling Performance 3
Speed 2
Maintenance 2
Ease of Upgrade Other (please specify)
  • What are the specifications of your original Wheely King RTR Model
  • What modifications have you made to your car & how has that improved the performance ALLOT ... Bta steering, Wider axles, tube top, Midgard ProRock chassis, Wheels and tires Rear lockout Steel drive gears Hardened Steel diff gears
  • What disadvantages do you see with the original Wheely King? Plastic drive gears, alloy diff gears
  • When you first used the Wheely King, what problems did you face? How did you resolve them? Electronics blew up after 2 weeks .... now all Traxxas .. VXL-3s and 3500kv BL Motor
  • Does the Wheely King perform the function that you bought it to perform? (See Question 2) Yes after extensive modifications
  • What design modifications would you suggest to improve the overall experience of your Wheely King? E-Savage diff gears as standard and a slipper to protect the gearbox ..... Better Transmitter, receiver and Servo
SnoopMaxx is offline   Reply With Quote
Old 10-02-2008, 11:38 PM   #12
Default Design of WK
Hi guys,
  • Have you ever used the Wheely King 4x4 before? YES, I have two of them.
    • 0-18
    • 18-35 *
    • 35+
    • Racing
    • Rock Crawling *
    • Fun
    • Passing time
1 (The best)
2 (Good)
3 (Average)
4 (Bad) * "in stock form"
5 (The worst)
Cost $210
Racing Performance N/A
Rock Crawling Performance sub par
Speed Poor
Maintenance Excellent
Assembly & Disassembly Easy
Ease of Upgrade To vague. Upgrade with bolt on's, or custom parts?
  • What modifications have you made to your car & how has that improved the performance? Custom chassis, shorter shocks, longer wheelbase, different transmission, etc, etc,. The only parts used from the original WheelyKing are the axels.
  • What disadvantages do you see with the original Wheely King? To short, to high, wrong tires, aweful electronics, weight balance, poor steering. (if you want it to crawl)
  • When you first used the Wheely King, what problems did you face? How did you resolve them? No power with the steering configuration. Put the servo on the axel.
  • Does the Wheely King perform the function that you bought it to perform? (See Question 2) No, not in stock form. It does now.
  • What design modifications would you suggest to improve the overall experience of your Wheely King? Get rid of the monster truckstyle frame, redesign the transmission and battery location. Improve the steering and make better axle mounts for the links and shocks.
Good luck with your study.
kdubb88 is online now   Reply With Quote
Old 10-03-2008, 08:28 AM   #13
Greetings Fellow Pittsburgher!
    • 0-18
    • 18-35 34
    • 35+
      • Rock Crawling
      • Fun
      • Passing time
1 (The best)
2 (Good)
3 (Average)
4 (Bad)
5 (The worst)
Cost 2
Rock Crawling Performance 4 OUT OF THE BOX BAD BUT WITH MINOR IMPROVEMENTS GOOD
Speed 4 to quick out of the box for a rock crawler, but keep in mind it was designed as a Monster truck RC
Maintenance 1
Ease of Upgrade 2
  • RTR, 27 trn motor,
  • Tummy tuck tranny replacement, Cutom upper and lower links, aftermarket link mounts, 45 turn motor, better shocks, ota
  • Nothing for what it was designed to be it is excellent
  • for crawling, tires, tranny stlye, weight distribution, ESC, servo placement,
  • When you first used the Wheely King, what problems did you face? How did you resolve them? to fast, replaced motor, tires to hard, replaced with pro line M2K Mashers, and a set of axial beadlocks...
  • Does the Wheely King perform the function that you bought it to perform? (See Question 2) It was flexy as heck and looked easy to modify into a rock crawler.. (I bought mine pre axial scorpion release)
crawler_king is offline   Reply With Quote
Old 10-03-2008, 09:42 AM   #14
Picky Fab'r/Acetal Junky
Offroader5's Avatar
--Have you ever used the Wheely King 4x4 before? Yes
--What age bracket do you fall under? 18-35
Why did you buy the Wheely King? As a cheap basher to have fun with, and then to later cannibalize to rebuild as a comp crawler.
-Cost: 2
-Racing Performance: 4
-Rock Crawling Performance: 3
-Speed: 3
-Maintenance: 2
-Assembly & Disassembly: 2
-Ease of Upgrade: 2
--What are the specifications of your original Wheely King? Not sure what you're looking for here. Try HPI's site.
What modifications have you made to your car & how has that improved the performance? Check out my build thread...too many to list: Custom Chassis'd WK Crawler
--What disadvantages do you see with the original Wheely King? Too top heavy & tires are kinda lame.
When you first used the Wheely King, what problems did you face? How did you resolve them? None that I can remember...it's been a while.
Does the Wheely King perform the function that you bought it to perform? It does now.
What design modifications would you suggest to improve the overall experience of your Wheely King? Of the stock rig...lower the trans and motor to bring down the center of gravity.
Offroader5 is offline   Reply With Quote
Old 10-14-2008, 07:00 PM   #15
    • 0-18
    • 18-35*
    • 35+
    • Racing
    • Rock Crawling*
    • Fun*
    • Annoying family members :smile: ********
    • Passing time
1 (The best)
2 (Good)
3 (Average)*
4 (Bad)
5 (The worst)
Cost 2
Racing Performance 3
Speed 3
Maintenance 2
Ease of Upgradem 2
  • What are the specifications of your original Wheely King? box stock with reversed chassis and jb'd diffs
  • What modifications have you made to your car & how has that improved the performance? in a class of it's own or at least the axle's are now
  • What disadvantages do you see with the original Wheely King?high cog and low chassis clearance
  • When you first used the Wheely King, what problems did you face? How did you resolve them? none took the stabalizer off the back lower link's
  • Does the Wheely King perform the function that you bought it to perform? (See Question 2) yes
  • What design modifications would you suggest to improve the overall experience of your Wheely King? lock rear diff at least
speedwheeler is offline   Reply With Quote
