Thread: final diff gear
Old 10-06-2008, 06:21 PM   #1
Default final diff gear
ok guys i need a lil help..i stripped the final gear and pinion inside my diff..i found 2 places that carry it and the gears themeselves cost $6 n then like $6-$7 for shipping therefore for the 2 gears i need its gonna cost me like $12...is there anywhere else i can get a set at? or does anyone have a set i can buy from them? heres a pic so u kno wat gears im talkin bout..
http://us.st12.yimg.com/us.st.yimg.c..._2020_22537386
resetpunk is offline   Reply With Quote
Old 10-07-2008, 05:02 AM   #2
http://www3.towerhobbies.com/cgi-bin...?&I=LXTB48&P=Z
$10.78 shipped from Tower Hobbies.
Did you try eBay?
"Edited to fix link "
EARRNHARDT3 is offline   Reply With Quote
Old 10-07-2008, 05:18 AM   #3
MWRCA'er
Mnster's Avatar
$6.97 shipped
Liquid rc
http://www.liquidrc.com/index.php?ma...oducts_id=1709
Mnster is offline   Reply With Quote
Old 10-07-2008, 12:08 PM   #4
~Doin' it Dawg style!~
TrailDawg362's Avatar
When you get the new gears, be sure to re-shim them for a tighter fit. Also check the pinion bearings for slop, and replace them as needed. I had one go bad and it allowed the pinion to "walk away" from the ring gear, which eventually stripped out. WK's are notorious for R/P gear slop, which leads to quicky trashed gears. Just a heads up post...
T.D.
TrailDawg362 is offline   Reply With Quote
Old 10-07-2008, 07:09 PM   #5
Originally Posted by EARRNHARDT3 View Post
http://http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTB48&P=Z
Did you try eBay?
link didnt work :-(
Originally Posted by Mnster View Post
sweet thx man! now i gotta order me one of em
T.D.
alright thx man..how exaclty do i shim them ? and by pinion bearing u mean the one that is in the shaft itsself? if so then i think thats y i stripped my gears..
Old 10-08-2008, 11:14 AM   #6
I used the large ones from this pack:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBMC2
I couldn't find any from HPI but these seem to be the right size. Place the shims behind the ring gear until the mesh feels right (no slop but still moves smoothly). Usually one or two does the trick. This moves the ring gear closer to the pinion gear. The pinion gear I refered to is the input shaft and gear on the axle. If those bearings go bad, you won't have good gear engagement and the diff gears will fail quickly.
T.D.
Old 10-08-2008, 06:00 PM   #7
alright thx man..ill have to order some of those then to or get sum at my lhs
Old 10-08-2008, 07:05 PM   #8
Hey guys a quick question I think I may have done the same thing but when I tore mine apart everything looked fine I did how ever notice when I took the diff apart it looked kike I chunked some of the bevel gears which bothy diffs were locked with lb weld so I replaced them put everything back together and it still makes a noise kinda like the spur and pinion are stripped but thats not the case either and it only makes thye noise when trying to statr to climb anh obstacle is this the same thing you guys encountered or could this be something totally diffrent I ve been in this hobby for a long time and can usually figure out whats going on bit this one has me stumped thanks for any help
cdl822 is offline   Reply With Quote
Old 10-08-2008, 07:48 PM   #9
yea thats the same prob i had..hmm u just gave me an idea..maybe i need to check my shimming cuz my gears look fine to but i figured it didnt take much for it to skip teeth..maybe i just need to reshim it..il check it out
Old 10-08-2008, 08:41 PM   #10
did you guys ever considered the slipper in the tranny? that might be somethign to look at, I had the same prob,, tore my diffs apart rebuilt, them, and th enoise persited, my WK has it's tranny gutted in order to lock the slipper in it
gearguy70 is offline   Reply With Quote
Old 10-09-2008, 08:17 AM   #11
2 piece pinions suck. buy the hardened gear set from hpi and be done with it.
kurt is offline   Reply With Quote
Old 10-09-2008, 10:26 AM   #12
sounds like u guys need to ckeek your shiming . i thought i did this to mine the other day but it was the spurr gear had 2 teeth off it an that where it sliped at
randy1 is offline   Reply With Quote
Old 10-09-2008, 07:42 PM   #13
nah i was on a rock and it got bound up and it clicked really loud and the rear end wasnt turning so i let off n then i did it again and felt the rear pumpkin and i could feel the gears skippin teeth but good idea
Old 10-09-2008, 11:04 PM   #14
hey guys I ujust noticed something on my rig I came home tonight from work and went in to the work room to look at the truck and noticed while the truck was completely together after I thought I solved my problem but didn't hear is my question before I tear all apart again with the driveshafts and all hooked up when I tryed to move the pinion on the rear axle there is no play but the front axles pinion is where there is movement a little front to back so what I am asking is this where I should reshim my pinion inside the front axle thanks.
Old 10-10-2008, 01:04 AM   #15
I would say shimming behind the pinion (inside the axle case) would be best. This will keep it closer to the centerline of the ring gear. I don't know offhand what size the shims are, but a quick look at the manual (that thing we never read:-P) should provide the answer. Can't seem to find mine at the moment...
T.D.
Old 10-10-2008, 07:56 AM   #16
Gold Star Baby!
rottenbelly's Avatar
I am running the metal tranny gears and shimmed my pinion now i just break axles. Gonna try the intergys. Strc rear lock outs work great.
rottenbelly is offline   Reply With Quote
Old 10-11-2008, 10:41 PM   #17
I finally think I figured out my problem it's not the diffs or incorrect shimming I am almost certain it is in the tranny tore it apart the other night and whay I believe happened was I had tried a mod that I found on here a while back about removing the spring between the two gears and replacing with a spacer such as a pre load spacer for a shock so I tried it and worked good for a while but it seems now it has maybe grounded down a little from the friction and was not pushing enough on the smaller gear in between the other two gears and I believe that is what is skipping and making the noise.I wanted to lock the tranny but really couldn't find any info so now I am wondering should I replace the gear set in the tranny or maybe order the hpi gear reduction box any comments or suggestions are welcome thanks,glenn
Old 10-12-2008, 12:52 AM   #18
You might want to replace the trans gears with an alloy set to eliminate the slipper entirely. There's a few companies that make them. The plastic teeth are probably worn enough to still slip under load. After thats taken care of, you could add the reduction unit and it should be good to go.
T.D.
Old 10-12-2008, 08:41 AM   #19
Gold Star Baby!
I got the metal tranny gears from ckrc (19 dollars)and havent had a problem since. I am running a rooster crawler with a 65t integy, with rear strc lock outs and shimmed front and rear diff. The only problem I have now is breaking front axles. Gotta have a weak spot somewere.
Old 10-12-2008, 11:08 AM   #20
You're breaking axles? That's odd, I haven't heard of anyone doing that, they seem pretty beefy. I did manage to snap the axle housing in two, though (bad landing off a berm!). I have the CKRC gears also, no probs since.
T.D.
