| | #1 |
| AWESOME! TOTALLY AWESOME! ![]() Join Date: Oct 2007 Location: gervais
| ok I'm on a low budget, so I'm going to get the r2 disconnect, and the x-trail chassis. would the wk axle do alright with the chassis? I was thinking on getting the skid plate that moves the links on the inside but with the width of the axle would that work? so should I get the regular skid plate that leaves the links on the outside, or could I get it to work with them on the inside? what the opinion? |
| Sponsored Links | |
| | #2 |
| ~Doin' it Dawg style!~ ![]() Join Date: Jul 2008 Location: Fox Valley WI
| There shouldn't be any issues with using those axles and chassis. I'm running the MFM long chassis (which is more narrow than the X-Trail) with WK axles, and the only thing that might be a problem is if the rod ends won't pivot enough (side to side) to allow the links to move freely due to the angle. There are several ways to mount the links at the axles, as far as running them more inboard or out. If the rod ends allow for the angle, you should get good triangulation depending on where and how you mount the links. Hope that helped. T.D. |
| | #3 |
| that actually helps do you know any rod ends that allow almost extreme angles? |
| | #4 |
| I've only used Traxxas and RC4WD rodends, so I can't say for sure if there are better units out there, someone else might be able to shed some light on that question. I know the RC4WD ones are really nice and solid, but don't allow alot of pivot...from my experience anyway. Someone else wanna jump in here? T.D. |
| | #5 |
| Pebble Pounder Join Date: Sep 2008 Location: usa
| kinda sounds like it depends on what ball end you use. im sure it can be done just mite have to do a mod or2 |
| | #6 |
| Conical washers and spacers will come in handy whatever you decide to use. It may take some tweaking to get it just right, I've been fiddling with the links on my tuber for awhile myself. T.D. |
| | #7 |
| .... ![]() Join Date: Aug 2008 Location: Northern, Mi
| The ax10 has angled rod ends that would work, they are for the upper link that mounts at the frame |
| Thread Tools | |
| Display Modes | |
