Thread: Kamikaze Kustoms Zero D Build
Old 10-13-2008, 11:43 PM   #1
Default Kamikaze Kustoms Zero D Build
Well, I have had this chassis in hand for a few weeks, but wanted to wait till after Crawlapalooza to start the build.
I will be using the Kamikaze Kustoms Zero D chassis.
First of all I needed to punch some holes in the skid so I could mount the side plates.
The R2D Trans, paired with a Axiom 55 turn lathe motor fits nicely.
I will be attempting to do BTA steering with this build. Here is the mount I made for my Battery and Servo, keep in mind it needs alot of work still.
A Small mock up, I will be using 1/4 inch solid aluminum rod for the links, I'm using the Althread for mock up, because it is easy to cut, and adjust.
I will have more in the morning. I have to say, this chassis is awesome, I have 3 inches of ground clearance and the highest point of the chassis, is just over a 1/16th of an inch above the tires.
Shaun is offline   Reply With Quote
Old 10-13-2008, 11:46 PM   #2
666
666's Avatar
Looking good Shaun, be creative!!!
I have one, but I have Bergs.....
666 is online now   Reply With Quote
Old 10-14-2008, 12:43 AM   #3
Looks like a good start to me. A+ for trying somthing new
Flyin Hawaiian is offline   Reply With Quote
Old 10-14-2008, 08:05 AM   #4
I´m gonna follow this build
SnoopMaxx is offline   Reply With Quote
Old 10-14-2008, 09:39 AM   #5
Can't wait to see the BTA steering
musk-rat is offline   Reply With Quote
Old 10-14-2008, 09:56 AM   #6
looking good, I did that same build with axials instead, it worked ok, you are going to have to spend some time thinking about the rear link configuration, with the r2d you can not mount the upper links on the inside of the chassis as the motor gets in the way, if you want pm me and I will try to dig up some pics....
mexiCAN is offline   Reply With Quote
Old 10-14-2008, 11:09 AM   #7
Gold Star Baby!
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
Thats pretty interesting I've been associating that chassis with Berg axles. I'll be watching for your next posts.
Stormin2u is offline   Reply With Quote
Old 10-14-2008, 09:48 PM   #8
Thank you for all the comments, I'm really inspired now!.
This is a rough cut of the tierod, and just an idea of where everything is going to set. I had to go back and check on some property we have in Kansas today, so I didn't get much work done in the 10 free minutes that I had.
Old 10-15-2008, 09:51 AM   #9
Here is an Update, I got an idea of where I want the links to end up. I also got a little more work done to the tie rod, the final version of the tie rod, will be made from 1/8 inch aluminum.
Still not finished with the tie rod, but getting closer.
What I'm planning on for the links.
R2D, is nice and snug inside the chassis.
Old 10-15-2008, 11:49 AM   #10
I need to pick up some harder springs, but this is what I got after a little work this morning. I found out that I can bump it up to 3 1/2" of ground clearance and still be able to stand it on its side with the r2, motor, and electronics sitting in it. I really need to get a hold of some shorter shocks.
Old 10-15-2008, 06:33 PM   #11
Chassis braces, and transmission installed.
Old 10-15-2008, 06:44 PM   #12
Kamikaze's Avatar
Lookin good shaun, nice to see the chassis used in a different application.
Kamikaze is offline   Reply With Quote
Old 10-15-2008, 07:32 PM   #13
Keep up the good work. Its nice to see someone use wheely king axles for a change.
LST022752 is offline   Reply With Quote
Old 10-16-2008, 09:21 PM   #14
OCCUPY RCC!
dezfan's Avatar
What length are the shocks are you using?
dezfan is online now   Reply With Quote
Old 10-16-2008, 09:33 PM   #15
120mm I believe, So far I like how it flexes, I do need to get some fuel tubing to limit the flex, 90 degrees is just a we bit to much, I'm shooting for about 30, lol. I'm thinking I'm going to drop the chassis back down to 3 inches of ground clearance, I'm wanting a small amount of flex, and a low CG.
Old 10-16-2008, 09:57 PM   #16
tjb
looks good Shaun, too bad you idn't get to try it at Palooza...
tjb is offline   Reply With Quote
Old 10-25-2008, 03:51 AM   #17
This build looks amazing. I agree with everyone else, i is good to see someone using WK Axles for what is a serious crawler for a change!
I loved reading the build thread on your last rig, but this one looks even better!!
iheartoldskool is offline   Reply With Quote
Old 10-28-2008, 04:18 PM   #18
Team Y-Town
4xFord's Avatar
Have you considered running droop until you get some shorter shocks?
4xFord is online now   Reply With Quote
Old 10-28-2008, 05:51 PM   #19
Thank you.
Thank you.
I'm not sure if I plan on changing shocks, I like how it is right now, I just need to limit the flex a little more and it will be good to go. I have tried droop out before, and I just didn't like it. Its to unpredictable.
Old 01-10-2009, 10:35 PM   #20
I've been busy and haven't had time to work on this, I finally got some time to today and got a bit done, I got my dig servo mounted, and I got my 1/8th" tie-rod made, it only took my a hundred cut off wheels to get it cut out, and I still have alot of clean up to do.
All I have to do is cut the links, and a drag link. Then I'm either going to polish everything aluminum or have it anodized red, what do you guys think? I can't wait till I finish it and my dad heals and I can go kick some ass at some comps..... Naw I'll loose anyway.
The servo is straight, it just looks weird in the pics, I still have alot of clean up to do on the tie-rod.
Sorry for the bad pictures.
Thank you,
Shaun
