Thread: what dose every one use for a bender to bend brake line
Old 10-14-2008, 04:02 PM   #1
Default what dose every one use for a bender to bend brake line
if someone could send me a link to a really good brake line bender that is going to do a good job thanx in advance
hpiontherocks is offline   Reply With Quote
Old 10-14-2008, 05:48 PM   #2
Crawling is a fad...
Nerve's Avatar
I did mine on the floor of my basement.
1) get hammer
2) get piece of wood
3) cut your brake lines to what length you need (factor in the bend as well)
4) get a heat gun (embossing heat gun I had at home)
5) heat the pipe up for a few seconds (wear a work glove)
6) position half of the pipe over the side of the wood
7) wack it with a hammer to bend required (approx)
8 ) repeat for others to match. Shape others as required.
Worked for me. My links might not all be 100% exact in overall length, but the bends are pretty close as well.
Nerve is offline   Reply With Quote
Old 10-14-2008, 09:27 PM   #3
i just got my pair of plyers and put them to where i wanted to bend and used my thumb
grizz is offline   Reply With Quote
Old 10-15-2008, 06:23 AM   #4
Mriswith's Avatar
I picked up a $20 little hand held tube bender, it sucked. It wouldn't do nearly tight enough bends. I now use the edge of my work bench, it's about 3/4 round over (left over formica kitchen counter top). For tighter bends I use the out put shaft, right above the chuck, of my little bench top drillpress. It's maybe 1/2 inch diameter and good for just past 90 degrees with out a flat spot in the tube. For the larger radius bends, ones that I could do with that $20 dollar bender, I just do those by hand. I bend up one tube by eye balling it, then trace it on some paper and use the paper for a template for any other I need.
Mriswith is offline   Reply With Quote
Old 10-15-2008, 08:23 AM   #5
Any auto parts store will have them, here is an example of a good one at Autozone:
http://www.autozone.com/selectedZip,78626/initialAction,accessoryProductDetail/initialR,1629355/shopping/selectZip.htm
I picked one up at Oriely's i think for $8.00 that does about 80 degree bend, but then by pushing a little against the edge of my work bench I can get 90.
sgtsteve is offline   Reply With Quote
Old 10-16-2008, 04:11 PM   #6
I am gonna make my own
How-To: Tubing Bender
SnoopMaxx is offline   Reply With Quote
Old 10-18-2008, 02:08 PM   #7
http://www.autozone.com/R,1550580/st...ductDetail.htm
here you go
i forgot to add , you need a piece of test tubing , make some marks on where you want the bend then measure for shrink (how much the tube shrunk by making the bend) this way once you get all your measurments and ad in for the shrink you will get perfect bends and hardly any waste
jombo is offline   Reply With Quote
Old 10-18-2008, 07:11 PM   #8
Hoss138's Avatar
I have a Cresant wrench that has a rubber coating. And I use the hole in the end of the handle.
Hoss138 is offline   Reply With Quote
Old 10-18-2008, 08:51 PM   #9
Practicing my launchs >:)
Robbob's Avatar
a couple of these work well
or you can use the parts store ones and Home Depot or Lowes has ones that can do smaller bend.
Robbob is online now   Reply With Quote
