| | #1 |
| Newbie Join Date: Oct 2008 Location: Calhoun
| I have a WK and am wanting to upgrade the motor. I am using this for bashing mostly. Will acquire a Axial for crawling. Looking for more power and maybe longer run times...new battery ect. |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Feb 2007 Location: MS Coast
| If you are looking for more power, maybe a 35t motor from HolmesHobbies or JPCustomsRC would be good for you. They will have more torque and only loose a little speed. As far as run times, to increase those you will have to get a battery with a higher mah. |
| | #3 |
| I wanna be Dave Join Date: May 2006 Location: AZ - In The 928
| Gunman - I'm using the HPI 20t motor in my stock WK with some PeakPower 3000Mah Nimh packs. I got quite a bit better run time and the stock battery. I also upgraded my spur(90t) and pinion(24t) and it's quite a bit faster and still able to pop a wheely. I plan on buying a new ESC at some point and dropping in a 15t or a mild brushless system in the future. |
| | #4 |
| Pebble Pounder Join Date: Sep 2008 Location: usa
| i had the hpi 15 turn in mine was a blast it was the hpi 15 turn |
| Thread Tools | |
| Display Modes | |
