| | #1 |
| Rock Stacker Join Date: Nov 2007 Location: fort collins
| I really need some help with this problem. I built a drooper widow chassis to replace my old low profile version, but now I have about .5 inches ![]() Here's why i'm skeptical of going to a sprung setup |
| Sponsored Links | |
| | #2 |
| NIDRCRC.com ![]() Join Date: Jul 2005 Location: Rathdrum, ID USA
| How long are those shocks? They look pretty short... |
| | #3 |
| Rock Stacker Join Date: Feb 2008 Location: Minnesota/Wisconsin
| the only way to get your ride height up is to make your shocks longer, I would go back to a sprung/semi-droop style shock. Otherwise, if your set on using the shocks set-up like that, you will have to have a shorter wheelbase |
| | #4 | |
To answer themerc's question, these are aftermarket tmaxx shocks. | |
| | #5 |
| Rock Stacker Join Date: Sep 2008 Location: cumbria
| id turn the lower links round as well so the bent part is at the axle end i had same set up on mine an cog was real low so turned em round an it lifted it up might not be that tho just a thought |
| | #6 |
| Quarry Creeper Join Date: Aug 2008 Location: iderho
| Go with some longer shocks. Other than that, it looks good |
| | #7 |
| Rock Stacker Join Date: May 2006 Location: willows
| | #8 |
| Picky Fab'r/Acetal Junky ![]() Join Date: Jul 2006 Location: Arizona Desert/AJ
| First...make sure you're not longer than a 12.5" wheelbase. If you are good at 12.5", then your shocks are too short. Having the links straight or bent makes no difference. |
| Thread Tools | |
| Display Modes | |
