10-31-2008, 09:27 PM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: Lawton
| Locked Axle Question
This may sound stupid, but is there any way to unlock a wheely king axle. I bought the truck from a guy on here a while back and they were allready locked and now since I have a few other crawlers I want to unlock them so I can have something to go kinda fast in. Its has real good wheel speed with the locked axles and stock 27t motor but I need to go faster every once in a while. thanx |
10-31-2008, 09:33 PM | #2 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
Well you need to find out how the axles are locked. If it's JB weld your out of luck. If it's spools then you can just put back in the gears. |
11-01-2008, 01:29 AM | #3 |
RCC Addict Join Date: Jan 2008 Location: Wetlands
HPI sells the diff replacement/ Upgrade for WK axles if you find yourself out of Luck.
11-01-2008, 12:20 PM | #4 |
Rcguy lockers were used do you think It can be unlocked?
11-01-2008, 12:52 PM | #5 |
Quarry Creeper Join Date: Jan 2008 Location: Edmonton, AB
yup
11-01-2008, 12:59 PM | #6 |
sweet what do I have to do?
11-01-2008, 03:48 PM | #7 |
Newbie Join Date: Apr 2008 Location: Canada
Your from Clinton BC? I'm in Kamloops and have my stock diff gears out of WK. I have the WK HPI conversion and it came with diff locks. So my stock side gears and spider gears are collecting dust.
11-02-2008, 09:42 AM | #8 |
Rock Stacker Join Date: Feb 2008 Location: Minnesota/Wisconsin
when I sold you the WK, I think I included the stock spider gears in a little baggie along with a bunch of other stock stuff. You should be able to just replace the lockers with the spider gears. Finding a how-to for installing the RCguy lockers should help show how to remove them and replace them with the spider gears. You should have the stock pinion/spur gears as well, installing those vs. the crawling ratio that was on it should help get some more speed out of it.
11-05-2008, 05:30 AM | #9 |
thanx guys
