Thread: 90 degree axle
Old 02-27-2009, 03:54 PM   #1
Default 90 degree axle
when you rotate the wk axle 90 degrees, do you need longer main shafts? i rotated mine but the shafts were too short. am i doing something wrong?
stanpede is offline   Reply With Quote
Old 02-28-2009, 01:02 PM   #2
what do you mean by rotating it 90 degrees. is your pinion pointin strait up or something? please show pic.
openeagle is offline   Reply With Quote
Old 02-28-2009, 01:26 PM   #3
Default mistake
i meant to say ,rotate the shock mounts on the axles
Old 03-01-2009, 10:36 AM   #4
ok yes you need to extend your upper link. you can use some allthred and some tubing or youcan do what i did. i used all thred, tubing, link ends, and tlt suspention kit.
Old 03-01-2009, 11:31 AM   #5
Yes, you will need longer drive shafts. I think it's the t-max shafts that you want, you will have to put the long part of the shaft on the short part of the stock shafts. But, do a search to make sure.
If you need more info look in the thread about hpi's crawler conversion. I'm pretty sure it's all in there
shierkahn is offline   Reply With Quote
Old 03-01-2009, 04:06 PM   #6
Default 90 degree mounts
Thanks again for the info. since i finally asked the right question, the answer is much more clear.
Old 03-01-2009, 08:00 PM   #7
yes the tmaxx drive shafts is what u want it depends on how long u ned but Any tmaxx shaft will work
bart is online now   Reply With Quote
