Thread: Why wheely king?
Old 03-06-2009, 04:54 PM   #1
Default Why wheely king?
Hi im wondering if I should get the hpi wheely king. I like bashing around and crawling so i thought this would be the perfect truck for me. I have a couple questions though My first question is if the stock esc on the wheelie king can handle a 7-cell battery. My second question is can I use a traxxas titan motor in the wheely king without doing any motor mount modifications? And also if I instal the traxxas titan motor can the esc handle it? aNY answers would be great.
arcee guy is offline   Reply With Quote
Old 03-07-2009, 08:41 PM   #2
evileddy420's Avatar
The esc should be able to handle 7 cells. the titan will bolt right in, and is a 27 turn, like the stock wk motor. If you are going to do any crawling, or slow speed stuff, the esc will get hot and shut off. adding a lathe motor for crawling will be much easier on the esc. hope this helps.
evileddy420 is offline   Reply With Quote
Old 03-07-2009, 08:49 PM   #3
Sucking Hind Teet.
Frankenwheely's Avatar
That set up would be good for bashing, but not really crawling. I kept in the 27t and did a lot of mods to make it crawler ready. Traxxas links, rod ends and driveshafts. STRC alum steering kit. Alum servo mount...etc. Plus HPI make a crawler conversion kit as well. That came out after I had modified it myself.
Frankenwheely is offline   Reply With Quote
Old 03-07-2009, 08:53 PM   #4
I stretched mine as well. I also added a 96 tooth spur, 17 tooth pinion, and a 75 turn lathe motor to make a great crawler. I eventually made it into a tuber and run it in comps all the time.
Old 03-08-2009, 07:58 PM   #5
My stock ESC wouldnt handle 6cells that would be the first thing id replace.
mindless is offline   Reply With Quote
Old 03-12-2009, 03:25 PM   #6
I know this is the WK forum but you asked for an opinion, so mine is get an ax-10. you'll be much happier. Sorry WK guys but you know the Axial is way more versatile
rocresq is offline   Reply With Quote
Old 03-12-2009, 03:29 PM   #7
Dont hate just because we work to make ours crawl. You have to have skills to make a WK crawl. Just yankin' your chain.
Justin
bigdodge88 is offline   Reply With Quote
Old 03-12-2009, 07:56 PM   #8
Justin
Hahahaha, good one, I haved learned so much with my wk convertin it and all, they are very very good,
grizz is offline   Reply With Quote
Old 03-12-2009, 08:09 PM   #9
Justin
I love my wk and know it front to back and inside out. http://www.scale4x4rc.org/forums/showthread.php?t=30059
booey is offline   Reply With Quote
Old 03-13-2009, 02:01 AM   #10
Sucking Hind Teet.
Why do you think I picked my screen name? I have both, but my heart still goes with the WK.
