Thread: WK doing the TWIST!!!!
Old 03-08-2009, 10:41 PM   #1
Default WK doing the TWIST!!!!
Ok what the hell!!!! As I try to go up an incline my WK wants to try to twist itself to the left, the front end lifts up and the entire truck twist left. How do I fix this???
Teknoron is offline   Reply With Quote
Old 03-08-2009, 10:47 PM   #2
Thicker shock oil and stiffer springs.
2JSC is offline   Reply With Quote
Old 03-10-2009, 11:17 AM   #3
Ok I put the heavest spring I have and put 80 wt oil in. It still twist like hell. Do I need more weight up front, am i trying to climb too slick of a surface?
Old 03-10-2009, 11:23 AM   #4
Keep it real
Tanis's Avatar
The link geometry on that is way out whack, that is the main problem
Tanis is offline   Reply With Quote
Old 03-10-2009, 12:22 PM   #5
How do i fix it, what do i need to do???
Old 03-10-2009, 01:20 PM   #6
Gold Star Baby!
rottenbelly's Avatar
I would start buy 4 linking the rear. Also try moving the lower links in some.
Here is the bottom of mine.
I moved them in so i could triangulate the links. The uppers are reverse of this and my torque twist is gone.
I made this bracket for the rear 4 link.
rottenbelly is offline   Reply With Quote
Old 03-10-2009, 02:02 PM   #7
Whycome U no have tattoo?
Ty@Tekin's Avatar
Put the stiffest spring on the left rear shock, if it's picking up the front right tire. That and a link re-do would be a good start.
Ty@Tekin is offline   Reply With Quote
