Thread: quick and cheap rear lock outs
Old 03-29-2009, 10:50 PM   #1
Default quick and cheap rear lock outs
dead simple mod and costs nothing. basically you remove the read hub, slide the rear axle out about an inch or so and pop a spring perch from the stock wk shocks over the shaft at the narrow section before the ball. reinsert the shaft, remount the hub and your done. no extra linkages or fancy parts and 100% reversible.
it will still have a little play in the hub but you won't even notice it while driving. you can se it in the picture below between the hub and the axle c
scruedloose is offline   Reply With Quote
Old 03-30-2009, 01:06 AM   #2
Cool but is that bondo on there?
Looks cool. Maybe it's gum. Explane.
username is offline   Reply With Quote
Old 03-30-2009, 02:10 AM   #3
JIA's Dad's Avatar
If it moves in a comp it would be considered rear steer and you would be DQed!!! Not good...
JIA's Dad is offline   Reply With Quote
Old 03-30-2009, 11:23 AM   #4
evileddy420's Avatar
I wouldn't trust that plastic piece to hold straight for long. Not the way I drive mine, anyway.
evileddy420 is offline   Reply With Quote
Old 04-01-2009, 10:59 PM   #5
03-30-2009 11:23 AM evileddy420
03-30-2009 02:10 AM JIA's Dad
true enough, it was just a quick and dirty atempt at a rear lockout so i could get out on the rocks to test my set up. works good so far but i agree it would not be a good idea for a comp. but for bashing about it should be fine.
03-30-2009 01:06 AM username Cool but is that bondo on there?
the white stuff is epoxy putty to reduce the chance of hang ups on the recess on the bottom of the axle c's (i've had it happen) . its also apllied to the lower of the front pumpkin and the lower of the rear pumpkin. most of the comps i've been to used a comination of blast rock and busted bricks which tends to snag the c's from time to time.
