Thread: wheely king axles on axial scorpion
Old 03-30-2009, 07:41 PM   #1
Default wheely king axles on axial scorpion
I have a 4x4 wheely king that I just upgraded the chassis and trans to a axial ax10 chassis, and trans. I'm using the wheely king axles. I seem to be having a slight issue with the drive shafts. Does anybody know what I would need to get the Axial trans to properly hook up with the wheely king axles. Any experienced info would be greatly appreciated
dwblue00 is offline   Reply With Quote
Old 03-30-2009, 09:13 PM   #2
I used traxxas half shafts #1951 and traxxas yokes #4628. The yokes are the right size for the axial trans but you will have to drill out the yokes for the wheely king axles but its not that hard.
openeagle is offline   Reply With Quote
Old 03-31-2009, 02:14 AM   #3
I was doing the exact same build, but I decided to spend the 70 bucks and go with the axial axles. But if you want to all you need is the 6mm to 5mm adaptor to go on the WK axles and the axial drive shafts will hook up.
calikingcrawler is online now   Reply With Quote
Old 03-31-2009, 07:36 AM   #4
Where do you get this adaptor?
Old 03-31-2009, 08:48 AM   #5
Gold Star Baby!
rottenbelly's Avatar
Here ya go!http://www.tcscrawlers.com/RC4WD-5mm...0-p-16417.html
rottenbelly is offline   Reply With Quote
Old 04-01-2009, 10:32 AM   #6
Originally Posted by rottenbelly View Post
Thanks rotten belly....I ordered these today along with some other misc. items. That looks to be the mose bullet-proof option. Cant wait to get it finished so I can post some pics. I have been lurking around here alot lately so I guess its my turn to post some pics, but everybody on here has probably seen it all.
Old 04-01-2009, 12:08 PM   #7
Sucking Hind Teet.
Frankenwheely's Avatar
Can those yolks be used on the axial axle side? I'm trying to run Stampede axles on an axial axle and tranny.
Thanks
Frankenwheely is online now   Reply With Quote
Old 04-01-2009, 12:23 PM   #8
Thanks
I would assume so. it would go from 4mm to 5mm. This might be better answered by some experienced builders. So if your axial axles are 4mm with the adaptor it would be 5mm, not sure tho on what size the yolks for the traxxas pede.
Old 04-01-2009, 12:28 PM   #9
I just want a bullet-proof drive train on this. Its going to be more for fun and bashing around than anything. Next ? I will have on this is whats a good steering servo to run, and steering linkage setup. I want to run a servo saver. I'll have to post pics here to show what I have right at this very moment.
Old 04-01-2009, 01:04 PM   #10
The yokes i am using fit perfectly on the axial trans you just have to use the set screws on both sides of the yoke unlike the wheely king with the pin type set screw.
Old 04-01-2009, 01:14 PM   #11
He we go lets see if thes pics make it.
Old 04-01-2009, 01:15 PM   #12
http://i624.photobucket.com/albums/t...0/100_0546.jpg
http://i624.photobucket.com/albums/t...0/100_0545.jpg
Old 04-01-2009, 01:17 PM   #13
Old 04-01-2009, 01:18 PM   #14
Old 04-01-2009, 07:19 PM   #15
Crawling is a fad...
Nerve's Avatar
Here is what I did to get the ax10 trans to match up w/ WK axles (care of Offroader5 btw).
Adapters for axial tranny to WK axle.
The original thread I found way back when:
AX-10 Trans - WK Axles?
Worked good for me and held up to its first comp so far.
Nerve is offline   Reply With Quote
Old 04-01-2009, 10:57 PM   #16
I am getting ready to build the same thing. WK axles with axial chassis and trans. The truck looks good.
KvilleKrawler is offline   Reply With Quote
Old 04-01-2009, 11:14 PM   #17
did same thing already, i wanted a decent dig unit. so i am running an ax10 trans with dna dig, and ax10 mip drive shafts. on the wk end of the shaft, you have to drill out the end of the mip shaft to 6mm. you will also want to add a 6mm washer or two between the drivshaft and pinion bearing. depending on you drivshaft legth, you may have to grind alittle off the mip splines. do some searching and measuring before ordering the shafts. also don't grind too much off the mip shafts, i found out the hard way that they are not fully splined. if you decide to go with the mips try here, they are premade for you.
http://www.thundertechracing.com/crawler.htm
auffquest is offline   Reply With Quote
Old 04-02-2009, 12:38 AM   #18
Sucking Hind Teet.
Thanks. That's what I'm doing with my stock axial axles right now. But I'm wanting to upgrade.
Old 04-02-2009, 12:22 PM   #19
Thanks guys! That tmaxx shaft to stampede shaft...I didn't think that would work. I thought t-maxx shafts were a bit larger. That gives me other ideas if this other setup doesn't work. I think the plastic slider shafts should hold up for what i'm going to do with the rig. I'll post more on here when I have made further progress, but for now thats what I have. Now i'm starting to look into steering servos and steering linkage setups for the front axle, and I want to run a servo saver......any good ideas? Let me know! Again thanks!
Old 04-03-2009, 07:22 AM   #20
If your going to keep your servo on the front axle then you need to spend the money and buy one that has a metal gears and out put shaft or when you hit something head on in to it youll break the out put shaft off.
