| | #1 |
| Newbie Join Date: Jun 2007 Location: east michigan
| I have a wheely king axles on a axial scorpion chassis and what type of steering servo do you recommend for a 2.2 crawler? I have the servo mounted on the front axle. As well, also steering linage reccomendations? let me know thanks. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Mar 2009 Location: Raleigh
| | #3 |
| Gold Star Baby! ![]() Join Date: Aug 2008 Location: Gone 1.1 crawling
| I like the Jr servos like the 8711 with 400+ oz's of torque. If you are looking for a good cheap servo look at hobbypartz.com. I use the towerpros and the exi226 for my kids and wifes rigs and they hold up fine. Price is great also! http://www.hobbypartz.com/2xmgmegehisp.html http://www.hobbypartz.com/60gexidise.html |
| | #4 |
| wow...lol I thought my servo had a lot more power over the stock one, mines at 126 oz, i could only imagine having 400+ oz... |
| | #5 | |
http://www.horizonhobby.com/Products...rodID=JRPS8711 | |
| | #6 |
| wow. thats amazing, now that I have spent a gazillion bucks on getting my rig built, the next thing on my list is to convert everything on the axles to aluminum - to go along with my new chassis. |
| | #7 |
| I was planning on running a BEC unit so I can use the battery power to power the servo for max power. I see that alot of people on here are using the hitech 645MG servo for their steering. Is this servo strong enough? My rig is currently this WK axles /w lockers, Axial scorpion chassis, stock radio, novak XRS esc, and integy 55T lathe motor, axle mounted servo. I plan on using it for bashing and playing around so I don't plan on going to any competitions. So let me know. |
| | #8 | |
http://www.teamnovak.com/download/in...fs/xrs_ins.pdf With radios that dont have end point setting running a castle bec you must be careful not to overdrive the servo or the castles burn out quick. I went thru 3 before i figured it out!! | |
| | #9 | |
| | #10 |
| Quarry Creeper Join Date: Dec 2008 Location: Greensburg PA
| i use the 645mg in my king and have been slamming it into everything at about 40mph and broke everything else but my servo. my hi tech servo has a lifetime warranty too |
| | #11 | |
http://www.ckrccrawlers.com/shop/ind...dex&cPath=1_15 As for torque twist, i triangulated my lower links. 4 linked the uppers and on the chassis side of the uppers raised them up a little.This is a pic of my wk tranny in a axial chassis, you can see where i drilled a hole for upper rear links. | |
| | #12 |
| I have the aluminum upper link mounts to make the wheely king into a 4 link. I have noticed that making it a 4 link it takes away some articualtion, is this normal? I also have wheely king shocks on it, and I also hae mirrored the trans the torque twist is still there. I like the 3 link setup because of the articualtion, but if 4 link is more than enough articualtion then i'll go back to 4 link. |
| | #13 | |
| | #14 |
| So if thats the case....the WK shocks are too long on the axial chassis with WK axles? Im looking into running fuel tubing as limiters inside the shocks. I also have about 3.25" ground clearance on this rig. Last edited by dwblue00; 04-05-2009 at 02:45 PM. |
| | #15 | |
The plastic spacers are less prone to splitting than the fuel tubing and stay out of the way of the oil flow holes in the shocks. | |
| | #16 |
| I have the aluminum upper mounts to make the WKaxle a 4 link and I have some t-maxx links to mount where your bodymounts on your axial chassis is. How would that work? |
| | #17 |
| | #18 |
| http://www.tcscrawlers.com/Visionary...h-p-16470.html These are what I have. I can run from these to where the body mounts are supposed to be. I moved my mounts up to just behind the shock mounts. Your set up looks good how does it work? How do you like the straight axle ends? |
| | #19 |
| BTW I appreciate your 1 on 1 with me in this whole setup |
| | #20 | |
That setup on mine worked great. it would crawl a steeper angle than a slightly modded ax 10 artr!!!! Your best bet is just try a few different spots with the links. I have a board setup with some griptape on it. I set it at a angle and try different setups. It is amazing how moving a upper link one hole up or down affects these rigs. It can mean the difference between lifting a wheel and rolling over completely. Glad i could help | |
| Thread Tools | |
| Display Modes | |
