| | #1 |
| Pebble Pounder ![]() Join Date: Feb 2009 Location: French Guiana
| Hello, Here my project of crawler on the basis of Wheely King. That summer a long process of transformation, of which here the result: Axle : WK, bloqued and HPI heavy-duty final gear Motor and ESC : Novak Goal Crawler with 18.5T brushless Transmission : RC4WD R2 with Dig Driveshaft : Punisher Shaft Body : Original HPI Wheely King (I love it!!) Battery : Lipo 2S Chassi, link...: Home made Tire : Panther Cougar Rims : Beadlock RC4WD 2.2 Suspension : HPI Aluminum shock with internal spring. Weight : 2.760kg - 6 pounds Some pics : ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I hope that will have interested you Last edited by TotoRax; 07-06-2011 at 06:39 PM. Reason: Error in title |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Mar 2009 Location: Raleigh
| Good looking rig! |
| | #3 |
| Quarry Creeper Join Date: Dec 2008 Location: Greensburg PA
| uhhhh DAMN!! thats nice. whats ur wb? like 3ft Last edited by chongdigga; 04-22-2009 at 01:39 PM. |
| | #4 |
| Pebble Pounder Join Date: Nov 2005 Location: Raleigh
| better pics of the bta please rig looks great and seems like a lot of neat goodies/ideas on it |
| | #5 |
| Quarry Creeper Join Date: Mar 2009 Location: north central IN
| I agree, more pics of the steering please |
| | #6 |
| Hello, Thank you for your comments Here some photographs of the steering : ![]() ![]() ![]() ![]() ![]() the steering is manufactured starting from an aluminum plate of 6mm. Last edited by TotoRax; 04-14-2009 at 09:15 AM. Reason: Further information |
| | #7 |
| | #8 |
| Sucking Hind Teet. ![]() Join Date: Aug 2008 Location: North Mexico
| | #9 |
| Quarry Creeper Join Date: Feb 2007 Location: Japan
| never seen bling crawl or look that nice! |
| | #10 |
| Newbie Join Date: Mar 2009 Location: Verona, KY
| looks good |
| | #11 |
| Rock Crawler Join Date: Nov 2007 Location: _______
| is that Foam your useing |
| | #12 | |
| Hello, Thank you for your comments Quote:
| | #13 |
| Hello, Some images of last the modifications of my crawler. ![]() Always old body of origin^^ ![]() ![]() Some modification on the front steering. It is simplified. ![]() ![]() ![]() Modifications of fixings of the links on the back axle. That makes it possible to make adjustments of the geometry of the rear wheels. Modifications of the suspensions with the external addition of springs. The springs are hard, and are utilies to absorb the shocks. The suspensions always function in full drop, the springs external intervene in the last. I replaced Punicher Shaft for of Mip for AX10, much lighter They was the last modifications on this project, before passing to another. Hum... That is said, but the modifications are never finished Last edited by TotoRax; 05-21-2009 at 03:40 PM. |
| | #14 | |
| Hello, I come to remove dust on this post Quote:
Here the third version of the chassis. The principal modifications are:
![]() Height under chassis : 7cm (2.75") with low, 8cm (3.15") with highest ![]() ![]() ![]() A small video. (To present in a comic way Bye Last edited by TotoRax; 09-04-2009 at 09:02 PM. | |
| | #15 |
| RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
| Great looking Wheelie King! |
| | #16 |
| Gold Star Baby! ![]() Join Date: Aug 2008 Location: Gone 1.1 crawling
| Man that thing is sharp!! |
| | #17 |
| Hello, Continuation and end of the modification on this version of the frame. After much of tests, the point modified following one :
![]() ![]() ![]() ![]() ![]() a little video, bye, |
| | #18 |
| Hello, Some update, The principal modifications relate to the front axle, in particular the BTA. The preceding assembly was too prominent and the servo were very exposed with the shock. Now, I use small a lipo, simpler to integrate on the axle. I repositioned the servo, it is placed much behind, less exposed to the shock and friction. The whole of the elements are placed low, to lower the center of gravity. ![]() ![]() The BAT system is remade in steel stem of 4mm. ![]() I changed the slope of the axle, so that the elements is more vertical and less exposed. ![]() ![]() The boly is from now on under the level of the tires. ![]() A little video enjoy |
| | #19 |
| Pebble Pounder Join Date: Sep 2007 Location: Portugal
| Hello (BadMax Nice ti see again the finest WK i ever see |
| | #20 |
| Thanks eFly !! a pleasure of meeting you here |
| Thread Tools | |
| Display Modes | |
