05-10-2009, 11:50 PM | #1 |
Rock Crawler Join Date: Oct 2006 Location: Germany
| Double-motor powered wheely-king tuber
This is the wk from Thilo, a friend of mine: This vid is from the first testride, needs to be dialed-in a bit, but it works: klick to youtube It has two esc, two 55turners and two HPI reduction-units that rotate in counter direction, so no torque twist is produced by the motor(s). One axle needs to be flipped for that reason. Hope you like it ... Pete |
05-11-2009, 12:08 AM | #2 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
So not trans just motors with redution and strait thru drive shafts?
05-11-2009, 12:22 AM | #3 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
05-11-2009, 12:55 AM | #4 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
Cool design. I like it. |
05-11-2009, 01:06 AM | #5 | |
gearing is a bit on the fast side, but the two motors have enough power for slow speed. But Thilo is thinking of getting the gear ratio a bit slower or using two 85 turners. Pete | |
05-11-2009, 01:16 AM | #6 |
Rock Crawler Join Date: Sep 2008 Location: Delta B.C.
very cool, low cg, independant controll over each axle..man i like it |
05-11-2009, 06:39 AM | #7 |
05-11-2009, 03:43 PM | #8 |
Rock Crawler Join Date: Jul 2005 Location: Rathdrum, ID USA
Hey greasypete. Can you get us some details on how he mated the gear reduction output shaft to the drive shaft yokes? He had to go from a 1/8" pinion shaft to either a 5mm or 6mm yoke... Thanks |
05-11-2009, 10:55 PM | #9 | |
you can get for rc-boats some reduction tubes. That slip over the pinion shaft and has a 5mm outer diameter. I will try to get a picture soon. Pete | |
