05-16-2009, 10:33 AM | #1 |
Newbie Join Date: Apr 2009 Location: Hong Kong
| HELP..Truck Throttles by itself...after turning on Guys,, need your advice.. as to what.. im not sure what happened.. 1 minute all is good.. then after resting for few minutes my wheely King would just WOT all by itself after i switch on the RX then TX ..plus i cant control it via my TX... no left no right...all it does is FuLL throttle... what seems to be the problem?? is it my ESC.... thanks 2 all in advance.. cheers |
05-16-2009, 12:08 PM | #2 |
Quarry Creeper Join Date: Aug 2008 Location: iderho
What electronics are you running?
05-16-2009, 10:30 PM | #3 |
05-18-2009, 01:44 PM | #4 |
Newbie Join Date: Mar 2007 Location: soldotna/alaska
You could check your throttle trim knob. Try turning it and see if it helps. If not, I'm not sure what it could be
05-18-2009, 03:38 PM | #5 |
Quarry Creeper Join Date: Feb 2008 Location: Irvine KY
Make sure its all plugged in right, and as rock-er stated check the trim on your tx
05-18-2009, 04:54 PM | #6 |
Newbie Join Date: Jul 2008 Location: Salida
I'm betting it is the esc. If you have a different one to try I would do that first. Not completely relevant but I had an esc do the same thing. It was a Novak explorer II, and as soon as I plugged in the the battery it would go full throttle. I believe it was caused by leaving a battery plugged in for years by the previous owner. I contacted Novak about it and they said it had some damaged mosfets... |
05-20-2009, 08:02 AM | #7 | |
Thanks GUys.. much appreciated... Apparently I dont have any SPARE ESC... my TX is set and to all low...but still can control the TRUCK everytime i switch on my TX truck runs with WOT full blast.. . probably ESC... Cheers. | |
05-20-2009, 08:10 AM | #8 |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
Are your crystals pushed in on your RX and TX?
05-21-2009, 05:28 AM | #9 |
Pebble Pounder Join Date: May 2009 Location: Capitan N.M.
I have a simaler problem. I run a rooster 55t combo, traxxxas reciver, and a tq3 transmiter. I set the throtle trim and after a few minuts of crawling and stop it walks away. I wind up doing this every time. What could it be?
05-21-2009, 12:26 PM | #10 |
Rock Crawler Join Date: Feb 2007 Location: Bridgeport
Not sure of the order you are turning things on but, be sure you turn on the radio first then the esc. Otherwise exactly what you described will happen.
05-21-2009, 09:04 PM | #11 |
Thanks. thats probably it i do turn on the esc first.
