04-09-2010, 06:20 PM | #21 | |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
I am going to drop down to a 11/96 ratio and try that. I want to throw a 3s on there but thought it might catch fire. The wheelspeed is great on 2s, i could only imagine 3s. | |
04-09-2010, 07:44 PM | #22 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
My motor doesn't get too hot... I don't even keep an eye on it most of the time. Maybe if I saw smoke I might get concerned But with the 3S lipo, it wouldn't make the motor run any hotter at low speeds. It just supplies more available voltage so it actually crawls smoother with a bigger battery. Kind of hard to explain... But yeah, its fast and powerful. I have had great luck with dependability the last 6 months (till March) I recently destroyed the rear carrier. The Axial sintered locker spun around 180* inside the carrier and sheared off the screws that hold the ring gear on. So I upgraded to Felsenfest spools Not a week later I got frustrated at a comp when my truck got all bound up, and I tried to power out of it. I got out of the bind, but I noticed my left rear wheel was "coasting" (figured I broke a wheel hex pin) So I called it quits and tossed the truck over by my tool box and the left rear wheel fell off, with about 1 1/2" of the axle shaft still attached to it. So yeah, kinda impressed that I snapped the RC4WD 6mm straight axle! I should post up pics... What is your truck geared right now? |
04-10-2010, 01:26 AM | #23 |
I was running a 12/96 with a HH Puller 500. I stripped a 96 and the motor was acting up so i put in my promax before the midwest challenge. I only had a 93t spur and 13t pinion. I ordered a new 11t pinion and a 96 spur so i am going to try that when i get home. My spurs are my biggest weak spot. I have the CVD's on front and plain ole STRC rear lockouts and have had good luck so far. I did bend a rear axle a bit at the midwest. I have only been running 2s 30c lipos. If the gearing helps keep my temps low i am going to throw a 3 s on there and see what happens. |
04-10-2010, 02:51 PM | #24 |
Rock Stacker Join Date: Jan 2009 Location: Norfolk
Ha what an awesome WK rig. I should have done that instead of freaking out and buying an axial.
04-10-2010, 05:07 PM | #25 | |
If I was going to build it over again... I would run the same chassis, but build a custom transmission using axial trans gears stacked straight up, and then run axial axles. Especially since they have Super 300's for the axials now! And my friend took some video of me jumping the truck this afternoon. I'll try to get it posted up soon! TOM | |
