06-25-2009, 08:37 PM | #1 |
Rock Stacker Join Date: Mar 2009 Location: Lattimore, NC
| Differential Crunch
Has anyone else experienced with there king, a crunching sound from the rear differential? If so how did you fix it?. It is only 2wd drive right now. I was also wondering if it has slipper clutch, I can't find that it does on the website. Could it also be the transmission, just wondering.
06-26-2009, 08:28 AM | #2 |
RCC Addict Join Date: Nov 2008 Location: Frederick
It just maybe the slipper. It is built in to the trany. You may also have broke a tooth in your rear.
06-26-2009, 09:37 AM | #3 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
The WK diff gears are known to fail pretty easily, shimming them tighter seems to help. If you're going to throw alot of power at them, there are upgraded gearsets available, I believe the Nitro RS4MT gears are hardened steel. Somewhere in this thread there should be a link. Hope that helped. A slipper clutch failure would affect both front and rear, so it's more likely an R/P gear that died if you only lost power to one end. T.D. |
06-26-2009, 10:06 AM | #4 |
There is no loss of power or any broken tooth. The gear is a little worn on one side but it doesn't look like enough to do what it is. I think you might be right about the clutch I just wasn't sure whether it was built in or what. thanks guys it has been a great help. If you have any other idea let me know |
06-27-2009, 11:04 AM | #5 |
| Final Drive gear stripped
I have done a little more examining of the gear and found out that it is the Final gear in the differential that is starting to strip. Now my question is where can i find one that is cheap. |
06-29-2009, 11:43 PM | #6 |
Rock Crawler Join Date: Dec 2007 Location: USA
06-30-2009, 12:35 PM | #7 |
Thanks, that was GREAT help, and cheap too. |
06-30-2009, 02:11 PM | #8 |
np ...i have to get a new set of final gears as well i just havent ordered em yet..
07-01-2009, 07:59 AM | #9 |
Rock Crawler Join Date: Sep 2007 Location: Denmark
07-01-2009, 07:19 PM | #10 |
Is that a direct drop in. It looks like it is but just want to know from someone with experience |
07-02-2009, 08:32 PM | #11 |
I ended up getting the stock replacement part from Myatomic.com. I also found out that soda cans make great shims. I used a paper hole puncher and scissors and it was good as new, just a side note Thanx for all yous guys help. |
07-09-2009, 12:20 PM | #12 |
| Finally back up and running
I finally got my parts in today and got everything back running properly. I ended up getting the stock replacement, and now it works like new |
