06-27-2009, 02:29 AM | #1 |
Newbie Join Date: Jun 2009 Location: right there
| Steering throw?????
im new to the crawling world and i started with a converted wheely king and i was wondering how yall are getting more steering throw out of them mine steers good, plenty of tourqe im using the traxxas 2056 waterproof servo with stock steering linkage, any input is greatly apreciated Thanks Daniel |
06-27-2009, 09:16 PM | #2 |
noone?
06-27-2009, 09:29 PM | #3 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
I dont think there is anything for the WK's that i know of. if your good at fabrication. some linkage might help but other than that?
06-28-2009, 02:23 AM | #4 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
Most of us mount our servos on the axle using a mount like this. http://www.crawlerx.net/index.php?ma...f2a1ff25276602 I made my own based on some templates found on this site. I also use the TCS crawlers steering linkage kit. With STRc aluminum knuckles and C's along with a jr 8711 my steering is great. If you are using the stock radio you can check your steering rate and make sure its not turned down. Be careful since it doesnt have end point adjusments that you dont overdrive your servo!! Otherwise it will burn them out quickly. Even more likely with a aftermarket servo. Here is a shot of my old WK setup with a tower pro servo. |
06-28-2009, 05:19 AM | #5 |
Pebble Pounder Join Date: May 2009 Location: Capitan N.M.
if your still runing the stock axel c's turn the wheels all the way left and right and where they tutch the steering arm trim it down some. this will give you a little tighter turns.
06-28-2009, 09:57 PM | #6 |
thanks for the help i have already moved my servo to the axle with a homemade braket i will try trimming the stock C's down a lil and see if that helped, and im gonna try and get the aluminum sterring linkage to hopefully that wil help, again thanks guys for helpin a newb P.S. its not the radio though im running spektrum i use it on all my race cars so i just got another Rx for the crawler, thanks though Daniel |
06-28-2009, 10:01 PM | #7 |
there is a pic of what im workin wit so far, not much but damn its fun, i need to put some weight in the wheels though |
06-29-2009, 01:14 AM | #8 |
Changing that steering linkage out should help it more. That plastic flexes like mad under stress to keep from breaking. Looks good! |
06-29-2009, 02:32 AM | #9 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
not trying to hijack a thread but does anybody make a conversion or parts to move the steering linkage to the back of the axle ?
06-29-2009, 08:49 AM | #10 |
prolly not it would be a lil complicated with your links and drive shaft coming down back there
06-29-2009, 11:38 PM | #11 |
Rock Crawler Join Date: Dec 2007 Location: USA
06-30-2009, 12:21 AM | #12 |
Well alot of people that have been trying them sorta are on the fence about them. some people love em because it works with thier set up and others hate em because it binds and gets in the way. the best way seems to run it above the center of the axle.
06-30-2009, 12:45 AM | #13 |
Rock Crawler Join Date: May 2009 Location: Hillsboro, OR / Kapolei, Hi
Do CVDs allow for more steering angle? The stock dogbones and cups start to bind when you increase the throw by notching the C's.
06-30-2009, 01:24 AM | #14 | |
[QUOTE] Quote:
With something like a intergy or novak 45 to 55 turn motor with no dig it would be ok. With a holmes handwound on 3c lipo,,, Disaster is inevitable!! | |
