06-30-2009, 01:49 PM | #1 |
Rock Stacker Join Date: Jun 2007 Location: NOR CAL
| Servo Mount, Buying, Which One?
Title says it all!
06-30-2009, 02:14 PM | #2 |
Rock Crawler Join Date: Dec 2007 Location: USA
| http://www.rcguy.com/product-p/me-009.htm only prob i had is when using bigger tires like the stock wk ones the tires will rub the mount so i shaved down the corner a bit so they wouldnt rub ;) |
06-30-2009, 03:34 PM | #3 |
Newbie Join Date: Jun 2009 Location: Sandy Eggo
Hey guys noob alert: I have a crawler king thats stock except for a STRC steering kit. Want to go with an axle mounted servo.....is the crawler king chassis diff then the wheely king? Cause my upper link mount hits the bottom of the batt tray stock at full bump....so if i did this mount the servo would stick up a good 1/2" further then the upper link mount and I'd be loosing 1/2" travel.....that make sense? Anyone delt with that before? |
06-30-2009, 05:40 PM | #4 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
Hard to beat this one!! http://www.crawlerx.net/index.php?ma...&products_id=1 I made my own based on some templates found in this section. It worked great !! |
07-10-2009, 04:39 PM | #5 |
Is the CKRC one any good?
07-10-2009, 09:02 PM | #6 |
Pebble Pounder Join Date: Sep 2008 Location: asheville
X2 crawlerx, it is cheap an very well made |
07-11-2009, 03:55 PM | #7 | |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
07-12-2009, 07:13 PM | #8 |
Would this be a better mount than straight over the axel? I would think it would clear the chassis better than a top mounted servo mount and also help with torque twist... |
07-12-2009, 07:47 PM | #9 | |
http://www.rcguy.com/product-p/me-009.htm Servo placement has no effect on torque twist except for lower weight placement. Link placement has the most effects on torque twist. 4 linking is a great start in fighting torque twist, As is shorter shocks. | |
07-17-2009, 09:50 AM | #10 |
Rock Stacker Join Date: Jul 2009 Location: Orlando
Try this one...... http://www.eastendmachining.com/whkicemostse1.html |
07-17-2009, 07:15 PM | #11 |
w/ these links right? http://www.eastendmachining.com/whkistliupfe.html what servo saver or horn should be used for this setup w/ a traxxas waterproof servo? |
07-17-2009, 07:26 PM | #12 | |
07-17-2009, 07:27 PM | #13 | |
I would just use a aluminum servo horn for a traxxas a servo. | |
07-18-2009, 05:09 AM | #14 |
07-18-2009, 03:26 PM | #15 | |
07-18-2009, 03:37 PM | #16 |
can anyone link a servo saver that would work with the traxxas waterproof servo and either the CKRC or EEM steering kit?
07-18-2009, 03:42 PM | #17 |
07-20-2009, 12:49 PM | #18 | |
07-20-2009, 01:15 PM | #19 |
