07-08-2009, 06:08 PM | #1 |
Newbie Join Date: May 2008 Location: Orem
| Need a little help
What would be the best after market for a servo savers....for the stock wheely king servo....
07-08-2009, 06:32 PM | #2 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
| You are on a crawler site so I am assuming you are talking about a wheely king that you use to crawl with. IMHO not even worth thinking about any servo saver on a crawler and the stock servo is very very weak even without a saver. My recommendation is to get a better servo. But if you are really really wanting to stay with stock and use a servo saver than i would say just get the stock replacement saver. "aftermarket" one wouldn't be any better. Savers are made to "give" as a certain resistance which you don't generally ever want for crawling. Have fun with the truck
07-08-2009, 07:00 PM | #3 |
Quarry Creeper Join Date: Jan 2008 Location: Calabash, NC
A stronger servo is a must. I agree with Crawlinmike, in most cases no servo saver is needed. I upgraded to a Traxxas 2075 waterproof servo on the axle (ok, but still weaker than a ton of crawler setups). I run an alloy servo arm with no saver and have never had a problem with it. My buddy is doing the same with the stock servo. Last edited by Zod Rhombus; 07-08-2009 at 07:03 PM. |
07-08-2009, 07:33 PM | #4 |
so I could just use a arm form the servo to the links then.....
