07-13-2009, 02:51 PM | #1 |
Pebble Pounder Join Date: May 2008 Location: alberta
| Ring and pinion wear
Ok so my brother in law knows nothing about RC cars so if he breaks it I fix it, I don't mind tho because I love to wrench on RCs but anyway, he brought me his wheely king that he's had for about 3 years and the diff sound like it was slipping, I put the crawler conversion on it for him last year so o instantly thought the ring and pinion busted some teeth since the diff is locked, I tear it down pull out the diff and no broken teeth, so I clean it up and throw the axle back together to check again, I check the shim of the diff and when I pull back on the pinion it starts to click but I can't seem to figure out how to shim it so the pinion will stay tighter to the ring gear, from what I can tell tho the 2 gears have worn down so much that they need to be replaced, any suggestions?
07-13-2009, 03:06 PM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Greensburg PA
| HD final drives
Sounds to me like it needs an upgrade to the HD drives. mine have help up to some brushless torture for a while now and no clicks. if they dont look bad than its the tranny idler gear thats clicking. aluminium upgrade $30 http://www.xtownrc.com/catalog/produ...oducts_id/5064 Last edited by chongdigga; 07-13-2009 at 03:16 PM. |
07-13-2009, 03:53 PM | #3 |
Well it's definatly the diff because the axle wasn't attached to the tranny when I got it to click and it would only click if I pulled on the pinion, I'm just wondering if I can just shim it or if the gears need replacing?
07-13-2009, 08:55 PM | #4 | |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
If they still click after adding shims the teeth are probably to rounded off already. | |
07-20-2009, 03:30 AM | #5 |
Newbie Join Date: May 2009 Location: Newcastle Down Under Aus
Make sure he 4 diff housing bolts are tight to ive had dramas with my housings stripping before an the crownwheel an pinion starts to slip to fix that i just drilled out the housings an nut an bolted them
