![]() | #1 |
Pebble Pounder Join Date: Jan 2009 Location: PCB, FL
I have CKRC tranny gears installed in my truck but I recently started to hear clicks when my truck is in a bind. The clutch gears are screwed together so I know it isnt coming from the tranny. The spur and pinioin still look brand new, to me it kinda sounds like its coming from the rear diff. I put my finger on the rear diff during a click and did feel a vibration. I still have drive to all four tires but I would like to know what is making this noise. Any ideas? |
![]() | #2 |
Rock Stacker Join Date: Mar 2009 Location: Lattimore, NC
I have had this problem before. I checked the differential gears in the pumpkin. Both gears were pretty worn, and once i replaced them I had no probs. ![]() |
![]() | #3 |
Rock Crawler Join Date: Jun 2008 Location: Naples
Yup it's the diff gears, you can replace them with HPI RS4 final drive gear set, hardened steel, the stock are pot metal. If you take the time to shim the gears to eliminate slop and get a better mesh, they will last much longer. |
![]() | #4 |
Newbie Join Date: Aug 2009 Location: anderson
ive found that if you take your axels apart and regrease them and clean them ![]() |
![]() | #5 |
that works ![]() |
![]() | #6 |
Thanks for the info guys. The clicking is only when the truck is really stuck, so it is kinda acting like the old tranny clutch did only it doesnt slip as easily. I figure a click is better than a broke axle or a popped out driveshaft. East End Machining has a new gear set for 5 bucks so I'm just gonna order a couple of those and see how long I can make them last. |
