| | #1 |
| Newbie Join Date: Jun 2007 Location: NOR CAL
| I just got a Integy 55t, what pinion should I start with? |
| Sponsored Links | |
| | #2 |
| Gold Star Baby! ![]() Join Date: Aug 2008 Location: Gone 1.1 crawling
| | #3 |
| Couldnt find my pinion box... I think its at the bottom of my spare parts box, what a mess! So slapped in the stock pinion, 26t, seems not bad, can crawl up a wall |
| | #4 |
| Pebble Pounder Join Date: Jun 2009 Location: Canada
| I used an 18t with my 90t spur for a bit. Good speed and good torque. Then got the 96t spur and a 16t pinion with my 55T Integy. That combo works best for me on 3s Lipo. I would try 18t or 16t (sorta in the middle) with stock spur as a starting point. Then from there you could go either up or down to suit your driving style. If the gears don't mesh properly you could buy the 96t spur gear from HPI which also in turn will give you more torque over stock spur. Do this if you don't want to trim the tranny. Last edited by Evandiego; 09-04-2009 at 02:51 AM. Reason: adding more info |
| Thread Tools | |
| Display Modes | |
