Thread: black widow
Old 10-05-2009, 11:49 AM   #1
slowride1's Avatar
Default black widow
has anyone ever tried to use a mfm black widow chasis on a w/k
slowride1 is offline   Reply With Quote
Old 10-05-2009, 01:41 PM   #2
Shafty Maniac
tarmo120's Avatar
I did the widow chassis out of the 5mm aluminium. Works really great. I also use the wishbone 3link that was uploaded somewhere in this forum. All you really need is 2 axial 55mm green or whatever color you want posts. They go between the ballends in the chassis to give it more stiffness.
tarmo120 is offline   Reply With Quote
Old 10-05-2009, 02:13 PM   #3
slowride1's Avatar
no not offroaders chasis the mfm chasis
Old 10-15-2009, 05:21 AM   #4
hey if you looking for a chassis for the WK then check out this one http://www.eastendmachining.com/rocrcrchforw.html
Dukeboy is offline   Reply With Quote
Old 10-15-2009, 08:45 PM   #5
I ran that wk bw set up for a while worked well but i did use a axial tranny with it. I dont really see a good way to run a wk trans with the chassis.
mindless is online now   Reply With Quote
