06-04-2010, 02:25 PM | #81 | |
Quarry Creeper Join Date: Apr 2009 Location: sandia park, nm
i'd say luck. i do comp mine and ran a stock dog bone for about 2 months. then within a week i broke 3. | |
06-17-2010, 12:39 PM | #82 |
Newbie Join Date: Mar 2010 Location: newport
you could grind them shorter but then thats gonna bring the pivot point back from under the pivot of the c's and the hub wich more then likely will cause some binding mabey??
06-17-2010, 03:15 PM | #83 | |
alright did some measuring with my blitz, they use the same outer axle... exact same hpi blitz CVD's will work with only making the flat spots, bearings are same size | |
06-18-2010, 09:47 AM | #84 |
Rock Crawler Join Date: Sep 2007 Location: Denmark
| Blitz and Firestorm use the same CVD axles |
06-18-2010, 10:36 AM | #85 |
| ya i think this will be the ticket! just need to put a small sleeve inbetween the cup and end of the axle housingto make sure the bearing dont roll out of the axle, other then that a lil grinding on the end and thats that! supersmoker81 scales10 Rickey p.s. i need to find your email again snoop so i can write you about gettin that gear again thanks, |
06-18-2010, 10:44 AM | #86 |
i got a set of mgt's to work. took a little too much grinding to make them fit proper. like rickey said the pivot points don't match up too well. gonna pick up a set of blitzes and give them a try. thanks for the hint. |
07-26-2010, 07:55 AM | #87 |
Rock Crawler Join Date: Oct 2009 Location: Columbia, SC
Did anyone ever get the blitz cvd's to work. Trying to build up a set of axles in anticipation for BWD's rerelease pro kit and the cvd's are the only missing link.
07-26-2010, 11:37 AM | #88 |
shafts are too small in diameter. stubs are the right size though.
07-26-2010, 12:01 PM | #89 |
07-26-2010, 03:06 PM | #90 |
RCC Addict Join Date: Aug 2007 Location: Rohnert Park
Jake's Performance Hobbies as a few sets of the RCP CVD's and various other Wheely King Goodies. Give us a Call - 707-586-3375 or email jphracing001@aol.com www.jphracing.com THANKS! |
07-26-2010, 04:36 PM | #91 | |
I couldnt find anything WK specific on your site. I'll try givin you a call tomorrow. Thanks for the heads up though. | |
07-27-2010, 01:16 PM | #92 |
5 sets left. Give us a call, did not add them to the site ... 707-586-3375 Thanks! |
07-27-2010, 02:27 PM | #93 |
Quarry Creeper Join Date: Apr 2008 Location: San Diego
Always when I run out of money... dang it. lol |
07-27-2010, 02:40 PM | #94 |
Just ordered mine. Really nice guy to deal with. Thanks!!! Cant wait to get em.
07-27-2010, 09:45 PM | #95 | |
rather difficult to make them fit. have to do much grinding and testing. still not too happy with the fit, cv pivot pin not exacly in line with knuckle screw. but they are a larger diameter and the stub/cups are beefier. here's a pic of stock mgt shaft, my shaft, then a stock dog. also, have to use 6x10 bearing in knuckle due to the stub being thicker. it can be done and is proving to be pretty strong. | |
07-27-2010, 10:10 PM | #96 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
I might know where there are a few sets....I could check into it if anyone needs them. |
07-27-2010, 10:11 PM | #97 |
Appreciate the pic. I might have to try that once/if the MIP's fail.
07-30-2010, 12:39 PM | #98 |
We've got 2 sets left .... Thanks for the orders guys!! |
07-30-2010, 04:35 PM | #99 |
Quarry Creeper Join Date: Dec 2008 Location: Greensburg PA
08-07-2010, 08:11 AM | #100 |
Sold all, thank you guys!! Have a few sets of knuckles and C left ....
