06-27-2010, 10:17 PM | #1 |
Newbie Join Date: Jun 2010 Location: Long Island
| Gear noise
I am starting to hear a 'click, click, click' noise coming from the gear box (unit where the spur gear attaches to) anyone else have these symptoms?
06-27-2010, 11:28 PM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: Peoples Republic of Kalifornia
Sounds lick the "clicker" gear is dying. It clicks under stress to protect the other gears, and drivetrain. After a while it wears out and clicks all the time. Double check to see if the clicking could be from the diffs - that can be the source too. Heres the clicker Check this mod: Sexy EASY CLEAN Trans Slipper MOD |
06-28-2010, 11:52 AM | #3 |
Quarry Creeper Join Date: Feb 2010 Location: Nevada City, CA
Also check to make sure you haven't broken any teeth off ANY of your gears, tranny, spur/pinion, and ring and pinion in the axles. More than likely it is the clicker clutch as mentioned above.
06-28-2010, 12:38 PM | #4 |
Its coming from the clicker like you said. The spur/pinion are fine as well as the drive axles. What would get damaged if I kept running it like this? I can live w/ the clicking |
06-28-2010, 02:40 PM | #5 | |
Pebble Pounder Join Date: Jun 2009 Location: Canada
There is a sticky in this section about locking this slipper. WK Tranny Fix I used Gorilla glue and a couple screws. Works great. You also can get aluminum gears and have the option of using a slipper or locking it out. It's on CKRC's website. Cheers! Last edited by Evandiego; 06-28-2010 at 02:42 PM. | |
06-28-2010, 02:45 PM | #6 |
IMHO the HPI Blitz Slipper Clutch mod with a home glued/screwed clicker clutch is the best route to go ! There is a thread on how to do it, it was very simple and has proved to me very effective for my use. I have yet to break anything since I did the mod, and the best part is you can tighten the slipper as you BEEF up your drivetrain.
06-28-2010, 08:06 PM | #7 | |
Thanks! | |
06-28-2010, 11:22 PM | #8 | |
http://www.ckrccrawlers.com/wk-alumi...ars-p-922.html Cheers! | |
06-29-2010, 11:26 AM | #9 | |
Once it breaks that's when I'll fix it. Thanks! | |
