12-15-2010, 11:22 AM | #1 |
Newbie Join Date: Jul 2009 Location: East Quogue
| How can i make my crawler king have 4 Wheel steering???
I have had my crawler king for about a year now. And i have done mods to it, just little things here and there. But one thing that i want to do is make it have 4 wheel steering. I know i need another axle servo mount, another servo. But what else do i have to do???? |
12-15-2010, 12:11 PM | #2 |
RCC Addict Join Date: Oct 2009 Location: In the mancave...
Off the top of my head..you'll need.. A servo, servo mount, knuckles, steering links, and depending on what kind of TX you using, you may need a Y splitter for the servo's (if using a 2 ch tx) if your using a 3 ch TX (with the 3rd ch being a three position) you won't need the Y splitter. The 3 ch willl give you independent control for each servo. If I forgot anything someone chime in...hope this helps.
12-15-2010, 04:30 PM | #3 | |
Pebble Pounder Join Date: Apr 2010 Location: Peoria,AZ
12-15-2010, 04:31 PM | #4 |
well my reciever has a therd "slot". i tried to plug in a traxxas sevo and nothing happened. What did i do wrong? it fit in correctly
12-15-2010, 04:42 PM | #5 |
Quarry Creeper Join Date: Apr 2008 Location: San Diego
Just because there is a slot on your receiver doesn't mean its for that. You need to get a controller that has a 3rd channel. I bought this set http://www3.towerhobbies.com/cgi-bin...&I=LXXRL8&P=ML Just add your servo's and your GTG. With this setup you can control just the front, just the rear, both turning the same, both turning opposite. |
12-15-2010, 05:24 PM | #6 |
| yup, i know that.. but as stated in the original post, he "did some mods here and there." though, he didnt say what mods he did. i didnt know if he made lock-outs or not, or if he bought the rig new or used, ect, ect.. and the lock outs are super easy to make.. just trying to give the guy some info...
12-15-2010, 06:22 PM | #7 |
Where can i get two new servos, that are pretty cheep. And im going to order that radio tonight and the turning linkage. I just made two new axle servo mounts. So now i just need the servos, and to put it all together. Do i need to do anything to the crystals? or is that what that controller dose?
12-15-2010, 06:35 PM | #8 |
If you order the controller then you can get two of their servo's. The front servo will have one plug into the receiver and the rear will plug into a different hole on the receiver. YOu can reuse the stock one so you only really need one for the rear. I ordered two of the Futuba ones when I ordered my radio. That radio doesn't have crystals. It will work A LOT better and ZERO interference. Once you have it all setup you go through the menu on the radio and turn on 4ws. From that point there is a switch where your thumb would be to switch steering between the 4 settings. |
12-15-2010, 06:37 PM | #9 |
