01-03-2011, 08:49 AM | #1 |
Newbie Join Date: Dec 2010 Location: Woodstock
| Crawler King Shocks/steering servo
Well, after just 1 weekend playing with my new CK, looks as if I have busted my front left shock. Oh well. I was already looking to upgrade shocks and springs anyways. Any suggestions? Also, I am wanting to go ahead and upgrade to the center mount steering servo mod, by using the East End Machining diff mount. What other linkages will I need to perform this? I will also, at the same time modify the plastic steering linkages to metal. I feel the plastic is quite flimsy, and along with the poor servo placement, affects steering quite heavily as well. Thanks in advance! |
01-03-2011, 10:00 AM | #2 |
Pebble Pounder Join Date: Nov 2010 Location: Mesa
I am a new owner of a used CK so I'm new to crawling but not to Rc. The first thing i did was to replace the steering! I've never seen a funkier set up that what is stock! I got the template from this forum and made my axle mount and I used 8/32 all thread and 1/4 in brass tubing with large tmaxx rod ends. I used brass because its all i could find at the time and so far has held up wonderfully and its easy to cut with a small tubing cutter (the kind used for copper pipes). I also made the rear steer lock outs and four link suspension brackets and rods. The four link nearly eliminates torque twist, I would highly recomend this mod! Very easy to do with simple tools and the parts are cheap. I think all of it was under 20 bucks including hardware- I had to use 4-40 because 3mm is hard to come by around here for some reason but it works just fine with no noticeable slop. So far so good with my stock shocks but I also see alluminum shocks in the near future. Still trying to get pics posted here! Ahh figured it out! Last edited by bluenosegoat; 01-03-2011 at 10:42 AM. |
01-03-2011, 10:27 AM | #3 |
bluenosegoat, please post up pics asap. I love home remedies to stuff like this. I am new to crawling as well...but not to RC, just like yourself. I had a tmaxx before this. Thanks!
01-03-2011, 10:45 AM | #4 |
Got the pic thing figured out finally! I know I should become a paying member.......... Neat though that it links you to my photo bucket when you click on the pic! Technology- how cool! |
01-03-2011, 11:04 AM | #5 |
| Theres a couple pics there now. The steering mount is very easy to make. I made mine out of steel and the the four link brackets out of alluminum (I've got all kinds of materials around my tinkering shop) I didnt think the four link would make that much of a difference but it really helps with torque twist along with heavier oil and stiffer spring setting in the rear. I tried tmaxx springs to find they are to stiff so stock springs with a spacer up top to stiffen them up a little works good so far with 60wt oil. As far as making the links just carefully measure and use the stock connecting rods as a basis and its very simple. I've since found stainless steel tubing but the brass is holding up just fine so I'll stick with it and it looks kinda cool too I think!
01-04-2011, 12:34 AM | #6 |
Quarry Creeper Join Date: May 2009 Location: Under Communist Occupation
Bluenosegoat - Nice lock-outs! Gonna have to grab some AL and 2 Traxxas turnbuckles and do that for my WK trail truck. |
01-07-2011, 12:31 AM | #7 |
Rock Crawler Join Date: Sep 2008 Location: Bakersfield
question for you guys with the crawler kings....what is the length of the shocks from eye to eye?
