Set up tips with stock chassis and shock spring question Any tips on setting up with the stock chassis( shock locations), and what brand springs are you guys using on the stock shocks? I may try to pick some up if I can find some that fit. Need some stiffer ones. |
save your money and buy some real shocks.... almost every WK/CK shock I have ever had has leaked and upgrading to something worth a darn will be your best bet in the long run. Search the F/S section and within a few days you'll find a deal worth going for. Other than that, extend the wheelbase and have fun/beat the snot out of it. if you must, savage springs fit, but are longer, so you have either have increased spring rate or cut them down a bit to fit the WK length |
http://i1141.photobucket.com/albums/...p/RC/154-4.jpg http://i1141.photobucket.com/albums/...p/RC/153-2.jpg http://i1141.photobucket.com/albums/...p/RC/127-2.jpg http://i1141.photobucket.com/albums/..._up/RC/173.jpg |
When I had mine on the stock chassis I actually cut a half inch off y springs to lower it witch gave it better cg and gave it the ability to actually drop a axle over a ledge to help it climb better. |
