Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: New to cralwing need help will a axial tranny work with wk axles
Old 09-16-2011, 10:01 PM   #1
Default New to cralwing need help will a axial tranny work with wk axles
Hi, Im new to the whole crawling thing. like to know if the axial transmission (Part# AX30487) will this tranny work in wheelieking axels, Im also gonna use the scx10 frame kit thanks.
151ironduke is offline   Reply With Quote
Old 09-16-2011, 10:13 PM   #2
Yes
demonoid369 is offline   Reply With Quote
Old 09-21-2011, 07:10 PM   #3
The wheely/ck drive shafts will not bolt up directly to the axial trans. The axial trans has 5mm out puts while the wheely/ck axles are 6mm. You will need 5mm yokes for the trans. I lucked out and just happened to have some 5mm yokes around that fit up with the the plastic shaft to the axle. I have also found that the splines on the plastic shafts are the same as Tmaxx shafts so there are alot of options but you still need new yokes for the axial tranny. I can post pics if you need.
bluenosegoat is offline   Reply With Quote
Old 09-22-2011, 08:42 AM   #4
Axial diffs and pinions work in wheely king axles. If you swap out the HPI gears for Axials, you get 5mm pinions, over/under drive and locker options. You can also get different sized Axial trans output shafts and run the larger Maxx sized 6mm shafts. So yes they work and there's a couple different ways to mate them up
Mriswith is offline   Reply With Quote
Old 09-22-2011, 07:50 PM   #5
I would like for you to post pictures and give me part numbers... if you can
Old 09-29-2011, 10:02 AM   #6
These are the shafts I'm using now- a mix of stuff that was laying around.
The front shaft is half vennom creeper and half wk. The rear shaft at the axle is from a tmaxx, hard to tell but its big! and the other half is wk with a 5mm yoke to the tranny. I think I'm using a 90 tooth spur and the clearance is pretty tight. I'm using the truck as a scale rig right now and the shafts are holding up just fine.
