09-27-2014, 03:01 PM | #21 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
| Re: Monster KING! Grave Robber
That Onyx puffed within 8 months while running the exact same electronics package you would get in the then current Slash plus shorter gearing, so I can't in good faith recommend them. The truck now has the 1/10 Velineon system that had been in my 1/16 Traxxas Fiesta until this past spring (since been replaced with a SV1/4600 2 pole that had been in my Tamia M03 Mini Cooper), so I am planning on going with a high C-Rated 3000+ mAh 3s this time, maybe Thunder Power.
09-27-2014, 06:14 PM | #22 |
Quarry Creeper Join Date: Aug 2014 Location: home
| Re: Monster KING! Grave Robber http://img.photobucket.com/albums/v6...erWKheadon.jpg do you think a 3s will fit in there? just a curios question... does it still do a lot of wheelies with the suspension stretched? |
09-27-2014, 06:40 PM | #23 |
I know a 3s will fit, I actually had the then slightly puffed 3250mAh 3s 45c that I had run in my Mini Cooper when it had the SV1/4600 2-Pole and it fit perfectly, even though it was bulged! It never wheelied with the 12t/XL5 combo, even on 3s since I had left the battery up front. Doubt it will happen now since I didn't change the layout then added a whole lot more tire. |
09-27-2014, 07:42 PM | #24 |
hm.. ok
09-27-2014, 08:29 PM | #25 |
Thinking about going 3s now?
02-03-2016, 09:17 AM | #26 |
Made a few more changes to the truck, added a Traxxas Tubez Revo TieRods to the front the used a Stampede aluminum tie rod for the drag link, installed a Hot Racing Servo Mount withba low profile Savox servo (may eventually donthat out back too), as well as Savage shocks and springs, which allowed me to drop the body down as low as it'll go. I do plan on adding E-Savage springs, since they'll drop it a hair and hopefully be a bit softer than the S21 fl. red springs, might even put the VXL3s ESC down where the servo went to lower CG a bit now that itnsits higher. And now for the pics! This is how it looked after the red tierods and serve setup were installed, that's the shocks sitting on the roof in this one too. And here it is with the Savage shocks installed! |
02-18-2016, 11:10 PM | #27 |
Been a while since I did it, but I got the shorter E-Savage (also know as the E-Zilla) springs and some Hot Racing 110mm limiting straps, dropped it back down to a more reasonable altitude than with the S21 springs. I did a little test driving today, looks like I might need to gear it up some to take advantage of the power and torque of the Velineon system on 3s, went WFT on asphalt and it stood up on the back of the body and flopped over on it's side in little over it's own now extended length! I do have a set of the Proline 17.5mm Brawler rims on back order and just got in a set of Destroyer tires in for it. I do need to order a set of disks for Vaterra's V100 sedans to use as a mock pinion brake and eventually a new a Robber body with a few other goodies planned for that |
02-19-2016, 09:51 PM | #28 |
| Re: Monster KING! Grave Robber |
02-25-2016, 11:56 PM | #29 |
02-27-2016, 10:47 PM | #30 |
02-28-2016, 03:05 PM | #31 |
Pebble Pounder Join Date: Jul 2007 Location: USA
Maybe I've just had my head under a rock, but that is the first time I've seen a servo disguised that way. I like it, it looks good. Nice looking rig.
02-28-2016, 05:16 PM | #32 |
There are at least a few mud trucks on here like that, just had to ape it for this build though!
03-07-2016, 12:31 AM | #33 |
No pics yet, but the rear steer is hooked up and functioning.
03-07-2016, 05:49 PM | #34 |
03-08-2016, 10:20 AM | #35 |
Truck is looking good. I'm glad that I am not the only one still running the WK. Have you done much running with those wheels? it looks like the offset is fairly substantial. How are the axles holding up with them? |
03-08-2016, 02:17 PM | #36 |
Thanks, I haven't run it much in this current form, as I'm having issues with the VXL3s' BEC not handling the draw of the servos all that well, but ztrength won't be an issue since I'm running the sintered gears and RCP/MIP CVD's on both ends. Hopefully the knuckles and C's hold up, if not, I'll look at RCP for those too.
03-08-2016, 02:28 PM | #37 |
Rock Crawler Join Date: Oct 2009 Location: OUT THERE
Great build the 4ws looks great. Looking to build a monster truck my self and this build just keeps the itch going. Keep up the great work: |
03-08-2016, 04:27 PM | #38 |
Kruger is right Joe , truck is looking badd ass. I really liking the headlight eyes. If you need some parts for your build Chris, hit me up , got tons of stuff needing to be used |
03-08-2016, 07:41 PM | #39 |
Thanks guys, a coworker and I both kinda want to get out mitts on AX10 Deadbolts to build those up into monsters now too!
03-11-2016, 06:38 PM | #40 | |
| Re: Monster KING! Grave Robber Quote:
Ooooo me first! I have been itching to do another Wk build, looking for axles. Sorry BJoe... | |
Monster KING! Grave Robber - Similar Threads | ||||
girly grave robber | extreme | Paint and Body | 14 | 07-13-2009 06:11 PM |
My monster grave robber!!! | ianpurdy1 | Large Scale Rigs | 1 | 06-10-2009 09:37 AM |
Grave Robber for crawler | rr14 | Paint and Body | 14 | 01-27-2009 08:49 AM |
grave robber | NoblesvilleKid | Paint and Body | 4 | 01-25-2009 04:48 PM |
would a grave digger bodyshell fit my wheely king | Ray | HPI Wheely King | 6 | 07-31-2007 07:49 AM |
