02-10-2013, 01:30 PM | #61 |
| Re: the ultimate crawler king.....
I like this! I have the HPI crawler king and was thinking about getting an axial wraith, but I might do something along this line as well! good job!
02-10-2013, 03:53 PM | #62 |
Pebble Pounder Join Date: Aug 2012 Location: lexington
Lol thanks, i still need to put up pics of my rear end complete, still gotta do the front end and get an rx/tx and servo
02-10-2013, 04:30 PM | #63 |
I am moving my steering servo to the front axle using the kit you linked to, also going to upgrade to a traxxas 2075 waterproof servo, the stock hpi one only has 40oz and the traxxas is 125... also installed headlights and tail lights in mine which i hooked up to the esc battery slot and it works great for nighttime crawling! I need to get pics up soon..
02-10-2013, 05:42 PM | #64 |
here is a try at some pics of mine when it was first ran out of the box |
02-10-2013, 06:04 PM | #65 |
Hitec makes a waterproof servo that has 180 oz in for around the same price and i will also be using the axle mount servo kit, but mine has a dewalt motor on it
02-10-2013, 06:24 PM | #66 |
well I already have the traxxas, but if it doesnt work like I want I will have to go with one that has more torque. I got pics now of the lights on it.. |
02-10-2013, 06:47 PM | #67 |
Looks good man, you done any more upgrades on it
02-10-2013, 07:08 PM | #68 |
Yeah hpi servos suuuuck, they put that same servo in the savage
02-11-2013, 06:47 AM | #69 |
no more upgrades yet, but i am working on them!
02-11-2013, 10:14 AM | #70 |
Hot racing and ebay usually has some really cool upgrades for the ck
02-11-2013, 02:09 PM | #71 |
I am looking to see if there is a way to convert the CK to 4 wheel steering, since the rear axle is the same as the front, it will steer if the rod is removed.. edit: found several good links on the conversion, that will be my next upgrade! Last edited by allanon1965; 02-11-2013 at 02:48 PM. |
02-11-2013, 02:24 PM | #72 |
Yes there is a way, you need two axle mounted servo kits, 2 servos and a channel splitter
02-11-2013, 03:44 PM | #73 |
will the stock esc handle 2 servos on the one channel?
02-11-2013, 04:45 PM | #74 |
It doesnt connect to the esc it connects to the reciever, but yes
02-11-2013, 05:13 PM | #75 |
oops, i meant the reciever..wasnt sure if it would handle 2 servos on one channel.
02-11-2013, 05:26 PM | #76 |
Yep it will, also get the 96t spur gear from kimbrough
02-11-2013, 06:13 PM | #77 |
what advantage will the 96 give me over the stock 90? should i put in the 18 pinion to replace the stock 21? i know that will increase the ratio...
02-11-2013, 06:23 PM | #78 |
It slows you down a lil but gives you more torque, ill probavly be using 17-20t pinions to find the best ratio fo me
02-11-2013, 06:34 PM | #79 |
well the stock ratio is 4.28 : 1 and the 96t w/18t pinion is 5.33 : 1 with the 55t motor while the wraith stock gearing is 4.00 : 1 with a 20t motor so I am taking it that the wraith is more of a "racing" rock crawler and the king is a slow strictly "how much can it climb" type of crawler |
02-11-2013, 07:09 PM | #80 |
Yeah the wraith is labled a rock racer. What are your plans for tire upgrades
the ultimate crawler king..... - Similar Threads | ||||
Disadvantages and advantages of changing my wheelie king into a crawler king? | dudeka | HPI Wheely King | 18 | 01-09-2010 04:38 AM |
KING OF THE HAMMERS: the ultimate rock race..... | STANG KILLA SS | Chit Chat | 35 | 02-28-2008 04:56 PM |
Ultimate Wheely King build | WKminer | Newbie General | 11 | 07-26-2007 12:54 PM |
