| | #1 |
| Newbie Join Date: Dec 2012 Location: roy
| i have a old wheely king i converted to a crawler king for my son. i would like to find a better chassis for it. does anybody have some suggestions for a better crawler type chassis? |
| Sponsored Links | |
| | #2 |
| ~Doin' it Dawg style!~ ![]() Join Date: Jul 2008 Location: Fox Valley WI
| The WK trans is harder to mount than the Axial gearbox, which most crawler chassis are designed for. That kind of limits your options. If you're somewhat handy at fabricating some simple L brackets it can be made to work with almost any comp style chassis on the market. |
| | #3 |
| Quarry Creeper ![]() Join Date: Aug 2007 Location: Casper, WY
| We've got a number of WK/CK based vehicles and I get the most information and ideas from SEARCHing. In particular, the Wheely King Crawler Picture Archive and here, in the general WK forum. When the WK was introduced, the axles were hot and people made a lot of creative and competitive vehicles from them. Skim this forum backwards, from page one to the present and you will find a wealth of information including how to make comp chassis compatible with the transmission and motor plates for clocking the transmission. |
| | #4 |
| i guess i need to shell out some more money for some high speed internet. then i will look at more of the build threads dial up sucks |
| | #5 | |
| Rock Crawler Join Date: Jun 2008 Location: Naples
Here is a link to some free custom chassis templates: My Uploaded Files Just print out the one you like, and it can be cut from various materials, cutting board, aluminum, plexiglass ect. Here is a link to some free PDF files, templates for clocked motor plate and a axle steering servo bracket: https://skydrive.live.com/?cid=4a947...105BA34%21175# these can be cut from aluminum or thin guage steel sheet Last edited by caymin last; 01-05-2013 at 08:33 AM. | |
| | #6 |
| thanks ill check that out |
| | #7 |
| Newbie Join Date: May 2012 Location: cda
| also search for "wk widow" chassis. very happy with mine. *edit* the link in the last post IS for the widow, among others. ha! |
| | #8 |
| what do you run for shocks? |
| | #9 |
| I used losi night crawler shocks i found on ebay, and springs I found at the hardware store that had a spring rate the same as losi white if i remember right. Plus, they were 45 cents a piece at the hardware store! |
| | #10 |
| Rock Stacker Join Date: May 2012 Location: Walker
| If you want to modify your wk/ck chassis it can be done. Check out my pics and posts on R2 trans in a ck. Hank |
| | #11 |
| Newbie Join Date: Oct 2012 Location: UK
| in my humble opinion, whether you're designing your own, or adapting the existing one, 3.5 to 4 inch shocks would be a good start, along with all the ingredients to make up your own links, and try looking on this site for the clocked motor templates for the WK gearbox. Alternatively, go for a different gearbox, the R2D can be had for next to nothing, and has to be the simplest gearbox to design a basic chassis for, goes well with WK axles too! ;) Good luck, and post pics of what you want to acheive, some one may be able to help more! |
| Thread Tools | |
| Display Modes | |
