Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: transmission question
Old 01-06-2013, 06:38 PM   #1
Default transmission question
Guys will the stock trans hold up to a brushless motor?? im thinking about using a 1200 kv. let me know what you all think please
jackedman is offline   Reply With Quote
Old 01-06-2013, 07:58 PM   #2
Default Re: transmission question
I ran an 8.5 BL system in mine for a summer, eventually the slipper mechanism will fail though. Check the WK links for mods to fix that. Ultimately, I rebuilt my WK using a beefed up Axial trans with C.I.'s modified output shafts.
TrailDawg362 is offline   Reply With Quote
Old 01-07-2013, 04:57 AM   #3
ok thanks for the info. whats the kv rating on a 8.5t motor??
Old 01-07-2013, 10:09 AM   #4
I think it's around 5800kV.
Old 01-08-2013, 04:57 PM   #5
ok ill keep that in mind when i look for a motor
Old 01-09-2013, 04:17 AM   #6
MSB
get some hardened gears or do the mod1 fix and you're good to go.
MSB is offline   Reply With Quote
Old 01-09-2013, 05:02 AM   #7
mod1 fix?? i havent heard of that one. could you shine some light on that one for me please
Old 01-09-2013, 07:25 PM   #8
I have been beating this setup for over a year with a 27t on 3s. Not one single issue
Wheely King Transmission Details
stolps is offline   Reply With Quote
Old 01-10-2013, 05:58 PM   #9
stolps thanks. I think ive read that thread at least 3 times now. Just one question for you do you have all metal gear like in the pictures???
Old 01-11-2013, 04:06 PM   #10
Yes, I'm running this setup. Just the top two gears are metal. The bottom one is the stock plastic one but I have never stripped that one out. Before going to this I was stripping the top two stock plastic gears every 7 or 8 battery packs. Since then, no problems at all with the transmission.
Old 01-13-2013, 06:03 PM   #11
ok thats awesome. I think im going to do that mode once i get my steering issure fixed. just so you know the savage transmission had the 28 tooth gear if you needed it. I had an extra one ripped apart cause of a gear problem.
Old 01-17-2013, 04:27 PM   #12
Do you have any more info on this. I looked through the manuals for all the electric and nitro savages and didn't see a 28t mod1 gear anywhere. Am I missing something?
Old 01-18-2013, 04:54 AM   #13
Thats my bad i recounted the gear and it turns out to be 29 tooth . Im not too sure if that would work but i might try it, just cause the other gears are 18 and 22 tooth so if i can get them all to fit that would be awesome
Old 01-18-2013, 02:57 PM   #14
No problem. I'm sure it will not work as the diameter is larger on the 29t.
Old 01-18-2013, 07:11 PM   #15
Im going to open the trans soon and take a look and if it works or fit ill post pictures and pm you about it with part numbers too
transmission question - Similar Threads
Transmission question.. Beej Axial Wraith 3 12-06-2011 11:59 AM
Transmission question MrCrash General Crawlers 14 04-03-2009 09:14 PM
Transmission question... phantom309 Tamiya Txt-1 and Juggernaut 7 08-29-2006 01:23 PM
Transmission question Section8 General Crawlers 7 07-26-2004 07:09 PM
