Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: ordered some more parts for my wk crawler
Old 01-29-2008, 07:05 PM   #1
Default ordered some more parts for my wk crawler
I ordered some axial black beadlocks, and a aluminum servo horn for my 645mg servo. but I can't decide on the tires that I'm going to use? which tires would you guys recommend for comp use cause I would like to go to a comp sometime. and see how I do. thanks for your help.
iceman320 is offline   Reply With Quote
Old 01-29-2008, 07:14 PM   #2
i would recomend the team losi rock claws
SMOKEY is offline   Reply With Quote
Old 01-29-2008, 07:23 PM   #3
Depends on the terrain. If its all out rocks, the claws should do good, but if there is some water or sand I'd say Mashers or Moabs.
2JSC is offline   Reply With Quote
Old 01-29-2008, 09:36 PM   #4
+1 on the losi claws there on 9 out of 10 rigs at most comps.
wheelspeed is offline   Reply With Quote
Old 01-29-2008, 10:28 PM   #5
well where I live it will be mostly rocks but the comp that I would like to go to is the comp in moab ut I live like 5 to 6 hours away form there. so I guess I will have to go with the rock claws since moab is all rocks and nearly no water. so rock claws it will be I guess. I will look at the moab's also though thanks guys.
Old 01-29-2008, 10:48 PM   #6
rock claws allllllll the way!
ruck"n"roll is offline   Reply With Quote
Old 01-30-2008, 08:32 AM   #7
alright rock claws it is then. and then later on i might get a set of moab's also so I can switch when i need to. thanks.
Old 03-09-2013, 09:48 PM   #8
Default Re: ordered some more parts for my wk crawler
I love proline beadlocks for comps but I run modded 2.2 interco boggers.
crawlerlover is offline   Reply With Quote
