11-22-2013, 09:08 AM | #21 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
I used a mount for a WK trans, low CG mount on Ebay and mounted to a Axial skid plate. If I were you I'd just buy a used Axial Scx chassis and trans or a used Wraith chassis and trans and use your axles, only difference is I made my own chassis but those other two options will get you the same results. Sent from the RAZR's edge |
11-22-2013, 09:10 AM | #22 |
Newbie Join Date: Nov 2013 Location: Michigan
Oh ok cool thanks......with the wraith chassis and trans will i need longer axle coming from the trans? I got a tight budget lol it be nice to keep it under 100$ |
11-22-2013, 09:13 AM | #23 |
That could easily be achieved, use either Tmaxx or Emaxx driveshafts and just cut to length, very cheap and durable. Sent from the RAZR's edge |
11-22-2013, 09:23 AM | #24 |
Ok cool.... So besides the chassis. Axles and trans what else would i need... I just ebayed the parts and there pretty cheap...a chassis can be bought for around 60$ with some links and mounts and stuff..and a trans is 30$ |
11-22-2013, 09:29 AM | #25 |
Really not much else, odds and ends, at this point you will need to mount servo on axle for now. Your just gonna need screws and such but I can't say for sure, you'll see as you go but won't be much. Sent from the RAZR's edge |
11-22-2013, 09:33 AM | #26 |
| My first wheely king
Ok cool..............i dont have to worry about screws i got plenty.... Ill probably start this project later cuz as most people---i got a tight budget lol..... Last edited by MechanicJoe18; 11-22-2013 at 10:29 AM. |
11-22-2013, 10:31 AM | #27 |
Also is the width for the axles different like the WK axles compared to the wraith axles?
11-22-2013, 10:56 AM | #28 |
Wraith axles are really wide, WK axles are narrower, but a little wider than Scx axles Sent from the RAZR's edge |
11-22-2013, 10:58 AM | #29 |
Ok so is no big deal?? Just wondering cuz i dont want it to look stupid after its all done lol
11-22-2013, 11:00 AM | #30 |
What you seen in my build is how it would look as a truck, would look good as a wraith too, lots of wraiths with scx axles and wk are only a little wider. Sent from the RAZR's edge |
11-22-2013, 11:37 AM | #31 |
Oh ok cool.....if it were you would u get a scx10 chassis or wraith
11-22-2013, 11:41 AM | #32 |
It all depends on how YOU want it to look, take a look at some 1.9 Wraith builds then take a look at scx builds. Sent from the RAZR's edge |
11-22-2013, 12:05 PM | #33 |
I just looked up a 1.9 wraith build and gotta say it looked cool... It had a shorter wheelbase and ford bronco stule body panels......im leaning towards that chassis.... I like the idea of not having a body to take on and off.. And it also seems that with that chassis it would crawl better...and be stronger |
11-22-2013, 12:09 PM | #34 |
I'm doin a 1.9 Wraith this winter for a trail rig, something to consider though, if you plan on comping the Wraith chassis is only legal in Class 3 scalers, just a thought. Sent from the RAZR's edge |
11-22-2013, 12:11 PM | #35 |
Lol no i am not considering any competitions lol....just something to have fun with... Thats my favorite part of the hobby is building stuff lol. I cant decide which way to go....i really want it to be a scale looking truck that can be used at some mild speeds like say 15mph but also be able to crawl.... |
11-22-2013, 12:28 PM | #36 |
I'd go with what appeals to you then, either will do the trick. Sent from the RAZR's edge |
11-22-2013, 12:30 PM | #37 |
Lol the wraith is what does right now....i seen a pic of it in the air lol and gave me ideas Basher/crawler |
11-23-2013, 04:02 PM | #38 |
I just decided to make my own chassis like the scx ... Just for the fact it will be cheap to make. |
11-23-2013, 11:27 PM | #39 |
| Re: My first wheely king
1/2" square tubing, a 4ft piece goes for under $10. Should be enough to do 2chassis rail sets. A couple differant ways to bend it, pie cut and heat and bend it.
11-23-2013, 11:30 PM | #40 |
