01-10-2015, 01:37 PM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: canada edmonton alberta
| slipper clutch
What slipper clutch can I bolt on to the rc4wd steel gear set?
01-11-2015, 12:27 PM | #2 |
Newbie Join Date: Aug 2013 Location: PRK
| Re: slipper clutch
Search for slipper clutch. Some one did an excellent job on a DIY Blitz clitch mod. I would suggest using the original shaft, a screw, some washers, and a spring to tighten that sucker up. Drilling the Blitz clutch shafts is a PIA. If I remember I will post a picture.
01-15-2015, 05:24 AM | #3 |
Newbie Join Date: Jun 2012 Location: kalispell
| Re: slipper clutch
I just finished installing the rc4wd steel gears in my wk to ck build. Didn't like the steel spur so here's what i did after reading about the blitz shaft mod. I had some extra slash items hanging out so..... I slipped a shorter pin through the top shaft sslid the new style locking plate and slipper plate on from the slash. I then had to fing a bushing that fit in the bearing of the outer slipper plate. Basically made the bearing a 3mm id bearing. I then took a screw about 35mm long installed a lock nut on it backward and threaded to to the top. Put a washer on the shaft then the spring then two washers. Little blue locktight thread the screw in all the way. Then just slowly tighten the nut until the slipper setting is where you want it. Trying to decide whether ot not to cut the head of the screw or not but haven't done it so far. Only downside is you cannot run the gear cover. So far this mod is worrking very well and ive ran 3500 kv 2 pole to 4000kv 4pole.
01-19-2015, 07:07 PM | #4 |
| Re: slipper clutch
sounds good any pics?
01-20-2015, 07:03 AM | #5 |
| Re: slipper clutch
Not very good ones. I will be changing the motor soon so I will get some out of the rig pics for ya. Crap I can't post pics on here.
01-24-2015, 07:57 PM | #6 |
Newbie Join Date: Oct 2014 Location: Saskatchewan
| Re: slipper clutch
I also did the blitz slipper in my wk. I used the wk output shaft and drilled the hole to hold the hub of the slipper in place. If I were to do it again, pay the $8 and buy the blitz shaft. I threaded in a long Allen bolt with locktite and cut the head off the bolt, for the adjustment of the clutch. Only thing is you are stuck with the blitz pinion gear which is higher than stock. But I run the gear reduction box so it's fine for me.
slipper clutch - Similar Threads | ||||
slipper clutch | theclimber | Axial Wraith | 9 | 07-18-2011 09:35 AM |
I know... Slipper clutch again!! | RickM | Axial AX-10 Scorpion | 26 | 04-15-2010 10:00 PM |
Slipper clutch? | losilover | Losi Micro-Rock Crawler | 7 | 04-07-2010 08:16 PM |
Slipper clutch | Chevyfanaddict | Axial SCX-10 | 3 | 04-12-2009 08:36 AM |
